what is SFP
sayhi2shashi
when u go thru the brousure of cisco switches , we will find most of the managable switches mentiones some thing SFP i.e
48 10/100 + 2 SFP ip base image
48 10/100/1000T + 4 SFP IP service image
and so on
what is this SFP ?
regd
Shashi
spremkumar
Level 9
Level 9
Hi Shashi
Its nothing but number of optic ports available in your switch.
SFP stands for Small Form Factor Pluggable fiber optic ports..
You can refer the below link for more info on the same..
http://www.cisco.com/en/US/products/hw/modules/ps5455/products_data_sheet0900aecd8033f885.html
regds
icabrera
Level 4
Level 4
Hi, SFP (Small form-factor pluggable) is a gigabit port. You have differents types, for copper and fiber optic (monomode or multimode).
When you have a description "48 10/100 + 2 SFP ip base image" this means that you have a switch with 48 10/100 ports and to slots where you can put SFPs interfaces, you have to decide what type you need.
Here some urls with SFPs types:
http://www.cisco.com/en/US/products/hw/modules/ps5455/products_data_sheets_list.html
Hope this helps, if so pls rate post
