Show Interfaces Output Errors / CRC (Frame Relay)
GRANT3779
Hi All,
Looking at an Output of a show interfaces command there seems to be a high volume of Input errors - and they almost tally up with CRC on the line below. The line is heavily saturated - would this be the cause? Or could the CRC be causing an issue? It is a frame relay link (512K)
Serial0/1/0 is up, line protocol is up
  Hardware is GT96K Serial
  MTU 1500 bytes, BW 512 Kbit/sec, DLY 20000 usec,
     reliability 255/255, txload 31/255, rxload 250/255
  Encapsulation FRAME-RELAY, loopback not set
  Keepalive set (10 sec)
  Restart-Delay is 0 secs
  LMI enq sent  110367, LMI stat recvd 110110, LMI upd recvd 0, DTE LMI up
  LMI enq recvd 0, LMI stat sent  0, LMI upd sent  0
  LMI DLCI 1023  LMI type is CISCO  frame relay DTE
  FR SVC disabled, LAPF state down
  Broadcast queue 0/64, broadcasts sent/dropped 18837/3, interface broadcasts 0
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 1w5d
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 7976
  Queueing strategy: weighted fair
  Output queue: 0/1000/64/0 (size/max total/threshold/drops)
     Conversations  0/8/256 (active/max active/max total)
     Reserved Conversations 0/0 (allocated/max allocated)
     Available Bandwidth 384 kilobits/sec
  30 second input rate 502000 bits/sec, 62 packets/sec
  30 second output rate 64000 bits/sec, 64 packets/sec
     74014842 packets input, 2195212513 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 101 giants, 0 throttles
     12589993 input errors, 12589924 CRC, 2758329 frame, 246617 overrun, 0 ignored, 3630022 abort
     69361072 packets output, 1961236740 bytes, 0 underruns
     108498 carrier transitions
     DCD=up  DSR=up  DTR=up  RTS=up  CTS=up
Leo Laohoo
Get the ISP to run a 4-hour Bit Error Rate test (aka BER test).
