show inventory gives unexpted output on ISR4331/K9
j.schouwenburg
Hello Networkers, I have a question regarding the output of show inventory and the snmp entity-mib.
Normally when I need an inventory of a IOS box I use the entity-mib or the show inventory information. The entity mib gives a lot of output of field replaceable units (FRU's) and non-FRU's. The show inventory command only displays the items marked as FRU.
On the ISR4331/K9 the output of both ways seems to have wrongly marked some items as FRU. Here is the output of a show inventory. The things that in my opinion and experience with other Cisco boxes should be removed (be marked as non-FRU) I have marked with a strikethrough. Is this indeed wrong or is this a new policy to report those items as FRU?
! ISR4331/K9 running isr4300-universalk9.03.16.02.S.155-3.S2-ext.SPA.bin"
ISR4331#sh inv
NAME: "Chassis", DESCR: "Cisco ISR4331 Chassis"
PID: ISR4331/K9 , VID: V02, SN: FDO2005A0AJ
NAME: "Power Supply Module 0", DESCR: "250W AC Power Supply for Cisco ISR 4330"
PID: PWR-4330-AC , VID: V01, SN: DCA193710UG
NAME: "Fan Tray", DESCR: "Cisco ISR4330 Fan Assembly"
PID: ACS-4330-FANASSY , VID: , SN:
NAME: "module 0", DESCR: "Cisco ISR4331 Built-In NIM controller"
PID: ISR4331/K9 , VID: , SN:
NAME: "NIM subslot 0/1", DESCR: "NIM-4G-LTE-GA Module"
PID: NIM-4G-LTE-GA , VID: V01, SN: FOC19490P6M
NAME: "Modem 0 on Cellular0/1/0", DESCR: "Sierra Wireless MC7304 4G-GA"
PID: MC7304 4G-GA , VID: 1.0, SN: 352761060562734
NAME: "NIM subslot 0/2", DESCR: "NIM-ES2-4"
PID: NIM-ES2-4 , VID: V01, SN: FOC19417UZW
NAME: "NIM subslot 0/0", DESCR: "Front Panel 3 ports Gigabitethernet Module"
PID: ISR4331-3x1GE , VID: V01, SN: JAB092709EL
NAME: "module 1", DESCR: "Cisco ISR4331 Built-In SM controller"
NAME: "module R0", DESCR: "Cisco ISR4331 Route Processor"
PID: ISR4331/K9 , VID: V02, SN: FDO200500BV
NAME: "module F0", DESCR: "Cisco ISR4331 Forwarding Processor"
0 Replies 0
