show ip route profile
musthafa786
I just enabled ip route profile in my router to verify routing loops or any abnormality in routing table, Below is output of show ip route profile ,
I can see only prefix refresh is changing , What does it mean  ? Is this need to consider routing table as inconsistent?
Could anyone put more detial on this ? thanks.
R1# show ip route profile
IP routing table change statistics:
Frequency of changes in a 5 second sampling interval
Change/   Fwd-path  Prefix   Nexthop  Pathcount  Prefix
interval  change    add      change   change     refresh
0         72        72       72       72           70
1         0          0         0         0             0
2         0          0         0         0             0
3         0          0         0         0             2
4         0          0         0         0             0
5         0          0         0         0             0
10        0         0         0         0             0
15        0         0        0          0             0
output truncated
Musthafa
musthafa786
Could anyone help on this ?
Hello Mohammed,
Prefix Refresh
- Standard routing table maintenance; the forwarding behavior is not changed.
For more info:
http://packetlife.net/blog/2010/jan/4/routing-table-profiling/
http://www.cisco.com/en/US/docs/ios/12_2/iproute/command/reference/1rfindp2.html#wp1058095
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
