show version in brief
Hi Experts,
Please explain show version out put in brief that means how to check available RAM , available NVRAM / used NVRAM , Available Flash & used flash .
Edison Ortiz
The documentation goes over this command in detail:
http://www.cisco.com/en/US/docs/ios/fundamentals/command/reference/cf_s2.html#wp1466984
HTH,
__
Edison.
In addition to Edison's comment, I will check NVRAM and flash with the following command
show file systems
example output
File Systems:
Size(b) Free(b) Type Flags Prefixes
...snip...
* 256471040 203329536 disk rw flash:#
245752 241091 nvram rw nvram:
...snip...
HTH,
jerry
