01-26-2015 02:31 PM - edited 03-05-2019 12:39 AM
I'm working a ASA 5505 in transparent mode version 8.2(4)
The shun command will not work.. comes back with invalid vlan 2
The interfaces are configured as:
Vlan 1 inside
Vlan 2 outside
Is the shun command turned off when in transparent mode?
Thank you for your time on this one.. I have been searching for an answer for over a week.
01-28-2015 12:14 AM
Hello, .
As i see from this documentation you can use shun command in transparate mode. But I see that at the IOS version 6 and 7 you don't need to use "vlan" word before number of vlan. But at the documentation that I saw you need to use this word. Maybe it's a problem?
Can you show example of your command and the text of the error?
01-28-2015 02:26 PM
