Unable to shut voice ports 1 + 2 on a Cisco 881-V. Haven't had much luck searching how to or if it's even possible. This is mostly for cosmetic reasons (creating new branch office template).
Was able to shut ports 3-7 (which correspond to the FXS/FXO ports on the router). The command shutdown is not available for ports 1-2 (which represent the BRI ports). I have shut down the BRI interfaces and it still shows admin status of up.
Router#show voice port summary
IN OUT
PORT CH SIG-TYPE ADMIN OPER STATUS STATUS EC
1 1 bri-voice up dorm none none y
1 2 bri-voice up dorm none none y
2 1 bri-voice up dorm none none y
2 2 bri-voice up dorm none none y
3 -- fxs-ls down down on-hook idle y
4 -- fxs-ls down down on-hook idle y
5 -- fxs-ls down down on-hook idle y
6 -- fxs-ls down down on-hook idle y
7 -- fxo-ls down down idle on-hook y
Commands available on port 1:
Router(config)#voice-port 1
STBC-PCI-001(config-voiceport)#?
Voice-port configuration commands:
bearer-cap Specify the bear capability
busyout Configure busyout trigger event & procedure
comfort-noise Use fill-silence option
compand-type The companding type for this voice port
connection Specify Trunking Parameters
cptone Configure voice call progress tone locale
default Set a command to its defaults
description Description of what this port is connected to
disc_pi_off close voice path when disconnect with PI received
echo-cancel Echo-cancellation option
exit Exit from voice-port configuration mode
input Configure input gain for voice
lpcor Voice port lpcor setup
music-threshold Threshold for Music on Hold
mwi Enable MWI on this port
no Negate a command or set its defaults
non-linear Use non-linear processing during echo cancellation
output Configure output attenuation for voice
playout-delay Configure voice playout delay buffer
threshold Threshold [noise] for voice port
timeouts Configure voice timeout parameters
translate Translation rule
translation-profile Translation profile
trunk-group Configure interface to be in a trunk group
voice-class Set voiceport voice class control parameters
BRI interfaces showing as down - does not reflect to the show voice port summary:
Router#show ip int brief
BRI1 unassigned YES unset administratively down down
BRI2 unassigned YES unset administratively down down
BRI1:1 unassigned YES unset administratively down down
BRI1:2 unassigned YES unset administratively down down
BRI2:1 unassigned YES unset administratively down down
BRI2:2 unassigned YES unset administratively down down
Anyone know how to have these ports show as administratively down? Might not be possible and technically it doesn't matter at the moment. Just more of a curiosity thing now.
Thx! (Running 15.2(4) code)
