Simple 2911 Question
Chris White
We have a new 2911 that needs to be configured, unfortunately it's at a remote site.  I had my hands and eye guy install the following config:
Current configuration : 944 bytes
! Last configuration change at  17:24:09 UTC Mon Feb 28 2011
version 15.0
service timestamps debug  datetime msec
no service  password-encryption
hostname  Router
boot-start-marker
boot-end-marker
enable password  test
aaa new-model
aaa authentication login default  none
aaa authentication enable default enable
aaa  session-id common
no ipv6 cef
ip source-route
ip  cef
multilink bundle-name  authenticated
license udi pid CISCO2911/K9 sn  FTX1504ALE1
interface  GigabitEthernet0/0
ip address dhcp
duplex auto
speed  auto
interface GigabitEthernet0/1
no ip  address
shutdown
duplex auto
speed auto
interface  GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed  auto
ip forward-protocol nd
no ip http server
no ip http  secure-server
control-plane
line con  0
line aux 0
line vty 0 4
scheduler allocate 20000  1000
end
Router#
Now, I do get a dhcp ip on the G0/0 interface and I can ping it from my remote network and the local router as well as the local lan.  The hands and eye guy is able to telnet from the local lan but I am unable to telnet from either my remote lan or the local router    The only error I receive is "connection refused by remote host".  All lines are clear so I have no conflicts with multiple telnet sessions.
Any help is appreciated.
8 Replies 8
andrew.prince
Level 10
Level 10
Chris,
As a temp measuere have your guy input;-
no aaa new-model
line vty 0 4
password cisco
This should get you on.
HTH>
johnlloyd_13
Level 9
Level 9
hi chris,
further adding to andrew's commen, kindly add the "login" command under line vty.
Hi Chris,
Below is how line vty 0 4 needs to be configured.
Router(config-line)#line vty 0 ?
<1-4> Last Line Number
Router(config-line)#line vty 0 4
Router(config-line)# password admin2
Router(config-line)# login
And also you can create access-list for security bindings. Below is the sample config as per best practices.
access-list 23 permit 10.10.10.0 0.0.0.255
access-list 23 permit 10.20.20.0 0.0.0.255
access-list 23 permit 10.30.30.0 0.0.255.255
Router(config-line)#access-class 23 in
Hope this helps you.
Please rate the helpfull posts.
Naidu.
If telnet is working from local lan then it's not an authentication problem but 2 things:
1) did you post complete running?
2)where are you trying to telnet from ---> just draw the topology with the addresses( modified for security reasons of course)?
3) are you using the same credentials as the eye guy?
It is looking more like a routing or ACL problem between your endpoint and the router you're trying to telnet in.
Regards.
Alain.
The 2911 is in Mexico and I am in Dallas and since I can ping from the desktop in Dallas, then we know the routing is working.  The config I posted is the full config so there are no ACL's or any security on the 2911.  Still waiting for the onsite guy to add the vty config.  I have tested the config I posted on a 2811 on a seperate LAN segment in Dallas and verified that it works.  Thanks for the help so far, will repost once the vty is configured.
*** UPDATE ***
Using the vty config doesn't help.
There has to be something on the 2911 that needs to be turned on.  This is a very simple config and has seved me will when trying to configure a remote router.  Jsut dont' understand why it's not working on a 2911.
Can you post the config after making the changes to "line vty"
version 15.0
service timestamps log  datetime msec
hostname  Router
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
ip source-route
ip  cef
ip address dhcp
duplex auto
speed  auto
no ip  address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed  auto
no ip http server
control-plane
line con  0
line aux 0
line vty 0 4
password cisco
login
end
Router#
Can you post the output of your ping and telnet to the router.
From which OS are you telnetting.
Can you also sniff on your computer while telnetting and put the pcap file here.
Regards.
Alain.
