througput on Cisco 871 ?
tiwang
Level 4
Level 4
Hi out there
I am trying to find some specifikation and test-reports on how much http-traffic you can put through a Cisco 871 router with inspect enabled - we have some customers which has increased there wan connection from 5 or 10 mbps to 20 mbps - and they claim that the don't get more than 8-10 mbps in througput - and I am looking for how much I can expect to get through this little box  best regards /ti
For those that can't see the document it says that the performance of an 870 router is 25,000pps or 12,8mbps (but that is for packet switching). That is probably the reason why.
Ian
12 Replies 12
IAN WHITMORE
Level 4
Level 4
Performance
Q. What are the performance characteristics of the Cisco 870 Series and Cisco 850 Series Integrated Services Routers?
A. Aggregate performance with IPsec 3DES for the Cisco 870 Series is up to 8 Mbps with IMIX packets, and up to 30 Mbps with 1400-byte packets.
Aggregate performance with IPsec 3DES for the Cisco 850 Series is up to 4 Mbps with IMIX packets, and up to 8 Mbps with 1400-byte packets.
For IOS Firewall performance, please refer tohttp://www.cisco.com/en/US/partner/prod/collateral/routers/ps5855/prod_white_paper0900aecd8061536b_ps1018_Products_White_Paper.html
HTH,
Ian
Hi Ian
The ipsec is also interesting but right now the problem is our customers have "local" internet access so what we are looking at is a setup where we are running  on a idle router which has a ADSL with 20 mbps down and 10 mbps up - and in the actual case the customer can run a internet based speedtest (http://tdc.dk/hastighedstest - based on ookla's flash-based speedtest-module) where he - when he is behind the router - can get around 10 mbps down and 8 mbps up - and if he removes the router and put his PC directly on the net he is up around the expected numbers ~ 19 mbps down and 9 mbps upload. Is this expected?
We have inspect enabled:
ip cef
ip inspect max-incomplete high 1100
ip inspect max-incomplete low 1100
ip inspect one-minute high 1100
ip inspect one-minute low 1100
ip inspect name ourfw tcp
ip inspect name ourfw udp
ip inspect name ourfw cuseeme
ip inspect name ourfw ftp
ip inspect name ourfw h323
ip inspect name ourfw rcmd
ip inspect name ourfw realaudio
ip inspect name ourfw smtp
ip inspect name ourfw streamworks
ip inspect name ourfw vdolive
ip inspect name ourfw sqlnet
ip inspect name ourfw tftp
ip inspect name ourfw rtsp
ip inspect name ourfw netshow
ip inspect name ourfw fragment maximum 256 timeout 1
ip inspect name ourfw http java-list 80
and running a simpel NAT:
ip nat inside source list 175 interface FastEthernet4 overload
where the access-list 175 just defines a few networks denied which is going though a VPN and the rest permitted directly - and here is the Fastethernet4:
ip address dhcp
ip access-group acl_103 in
ip inspect ourfw out
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
no cdp enable
crypto map cm-our
I'll try to disabled the inspect part to see if this gives us any difference. The white paper looks a bit optimistic to me...
871 are able handle 20 Mbps wan link.
Please ask your provider to test the link throughput and also you can do from your side with tool "iperf" which is best tool to test wanlink throughput.
However, here are some general comments:
  • In an ideal world with 1400-byte packets (all packets same size!) and no other services running on your 871 you can get an aggregate performance with IPsec 3DES of up to 30 Mbps theoretically.
    I guess that this is why you think that 18Mbps should be possible.
  • If we now move to the much more realistic IMIX packets (typical mix of different packet sizes) then the IPsec 3DES throughput already drops to 8 Mbps based on the Spirent IPSec IMIX definition.
  • In the real world you typically run other services on the router as well, like IOS-FW, NAT and ACLs. Your aggregate performance now drops to about 4 Mbps based on IMIX packets.
  • Things can even get worse if you use a 871W router with BVI configured. This cuts your aggregate performance down to about 2 Mbps based on IMIX packets.
Please rate the helpfull posts.
Naidu.
Hi Naidu
In the actual case the customer has tested the connection without router (eg: A pc re-configured with the IP adresse etc of the WAN I/F of the router and connected there instead of the router)  - and then he can get about 19 mbps in download and 9 mbps upload - on a 20/10 mbps ADSL connection.
Right now it is interesting what we can get through the router when we have the firewall services running with ip inspect enabled  - if I look at a report like
http://www.cisco.com/web/DE/pdfs/verticals/smb/isr-871-teststudie-engl.pdf
I can on page #14 see numbers which look much like what we see here - even though it might be able to handle ipsec etc very fast. Can you confirm these numbers?
best regards /ti
Yes.. And as mentioned, It have a great features including default vpn tunnel support, latest DMVPN technology and many more.
Naidu.
hi again
ok - this also means - as far as I can see -  that we should go for a more powerfull router when our customers are upgrading their ADSL connections to 20 mbps downstream or more - even if the 871 technically seen is able to handle a 20 mbps WAN connection - becuase if you load fw and inspect on it your realworld http throughput is going really down then?
best regards /ti
That is true...
Actually the c871 is for small business organization where you can terminate below 10 Mbps wan link and can utilize all its features without any issues.
But if you look at upgrade to morethan 10 Mbps say 20 Mbps then I would suggest go with 2921 router. Of course a 871 can handle at this stage but as a network admin we need to look at other features utilization and also system resources utilization which is more important.
Below are some specs of 2921:
  • 3 Integrated 10/100/1000 Ethernet ports with 1 port capable of RJ-45 or SFP connectivity
  • 1 service module slot
  • 4 Enhanced High-Speed WAN Interface Card (EHWIC) slots
  • 3 onboard digital signal processor slots
  • 1 internal service module slot for application services
  • Fully integrated power distribution to modules supporting 802.3af Power over Ethernet (PoE) and Cisco Enhanced PoE
  • Security
    • Embedded hardware-accelerated VPN encryption
    • Secure collaborative communications with Group Encrypted Transport VPN, Dynamic Multipoint VPN, or Enhanced Easy VPN
    • Integrated threat control using Cisco IOS Firewall, Cisco IOS Zone-Based Firewall, Cisco IOS IPS, and Cisco IOS Content Filtering
    • Identity management: Intelligently protecting endpoints using authentication, authorization, and accounting (AAA), and public key infrastructure
  • Voice
    • High-density packet voice DSP module, optimized for voice and video support
    • Standards-certified VoiceXML browser services
    • Cisco Unified Border Element capabilities
    • Cisco Unity Express voicemail support
    • Support for Cisco Communications Manager Express and Survivable Remote Site Telephony
  • Please rate the all helpfull posts.
    Naidu.
    tiwang
    Level 4
    Level 4
    hi out there
    If somebody else have done similary observations related to the 871 then please let us know - it is pretty important to us so that we advice our customers correctly and sell the correct equipment to them  so that they got the best solution...
    best regards /ti
    Well here is another official document from Cisco which suggests the real throughput is much lower:
    http://www.cisco.com/web/partners/downloads/765/tools/quickreference/routerperformance.pdf
    Yes it's from 2009...even so...I would recommend a different router to maximise the 20mbps throughput of the WAN link.
    HTH,
    Ian
    Ian
    thanks Ian - had these specifications just been simpler to find...
    Tell me about it!! Good job I'm unemployed and have time on my hands
    Now to think of a good excuse to tell your clients...
    Ian
