SIMPLE ACCESS LIST
cigalahgroup
     I have 887 router , which is attached to a server with ip address 192.168.0.10 and the routers VLAN1 is 192.168.0.1
I would like to block all internet traffic on the server except port 80 and 443. I did the following below
ip access-list extended 101
permit tcp any host 192.168.0.10 eq 80
permit tcp any host 192.168.0.10 eq 443
deny ip any host 192.168.0.10
and on the interface vlan1
ip access-group 101 in
13 Replies 13
Seb Rupik
Hi there,
The ACL you have created should be applied OUTbound on the VLAN1 SVI.
cheers,
Seb.
you mean to say
interface vlan1
ip access-group 101 out
Yes. If outbound access-groups are supported.
If not, try @luis_cordova implementation. Keep in mind that doing it this way would permit devices to still send traffic to the server, it would only be able to reply on TCP/80 and TCP/443
cheers,
Seb.
luis_cordova
Hi @cigalahgroup
Try this:
permit tcp host 192.168.0.10 any eq 80
permit tcp host 192.168.0.10 any eq 443
deny ip any any
int vlan 1
Hello
permit ip any any
interface vlan1
ip access-group 101 OUT
Kind Regards
Paul
I only want to access internet with port 80 and 443 and all other ports should be blocked
Hello
So if this isn’t correct do you wish all hosts jn vlan 1 to be denied internet access other than this server and that’s only allowed for http- https
So you have any other vlans - plus the fact that vlan 1 is a private subnet  I assume the rtr is performing Nat?
 Post the config of the rtr so we can obtain a clearer understanding of the rtr setup
Kind Regards
Paul
Here is the config
version 15.5
hostname woo
boot-start-marker
boot-end-marker
enable secret 5 $1$DTRE$zvzwB3cIB0/1L/
no aaa new-model
ethernet lmi ce
ip cef
no ipv6 cef
license udi pid C881-K9 sn FCZ2244116S
username cisco
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
no ip address
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
interface Vlan1
ip address 192.168.0.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
ip tcp adjust-mss 1300
interface Dialer0
bandwidth 1024
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp chap hostname 471@1024.verizon.com
ppp chap password 0 ***
ppp pap sent-username 471@1024.verizon.com
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source static 192.168.0.10 8.9.10.11
ip route 0.0.0.0 0.0.0.0 Dialer0
snmp-server community public RO
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
no modem enable
line aux 0
line vty 0 4
exec-timeout 120 0
password 7 13061E010803
login
length 0
transport input all
transport output none
line vty 5 15
login
transport input none
scheduler allocate 20000 1000
end
Hello
do you wish all hosts jn vlan 1 to be denied internet access other than this server and that’s only allowed for http- https?
Can you confirm what exactly you wish to happen?
Kind Regards
Paul
Simply I want to give internet access to only one computer 192.168.0.X and only from outside all the ports should be blocked but from inside I should be able to browse internet
Hello
So then you really don’t need a acl for that you just have to amend your static nat statement
ip nat inside source static tcp 192.168.0.10 80 8.9.10.11 80 extendable
ip nat inside source static tcp 192.168.0.10 443 8.9.10.11 443 extendable
no ip access-list extended 101
Kind Regards
Paul
Joseph W. Doherty
BTW, remember every ACL ends with an implicit deny all, so your last ACE is redundant.
Besides revisions/corrections suggested by other posters, you're blocking more than just Internet traffic.
Deepak Kumar
After reading complete statements, I got that you want that  Services hosted on Port 80 and Port 443 on the server must be accessible from the Internet (WAN) and the server can still access the internet as an end-user.
As @paul driver mentioned that you have to configure two NAT statement for make port forwarding from WAN to LAN (Server):
This will be useful for you.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
