Showing results forĀ
Search instead forĀ
Did you mean:Ā
Routing IPv6 on crossover cable
johndexters1100
Hi Guys!
I am still new on using cisco so please help me to understand this problem.
I had this problem whenever I ping the other PC is being'request timed out'.
I tried to use the static routing but it's not working.
Can anyone recommend what can I use to fix this problem? Thanks in advance
Deepak Kumar
You configured Static routes the same as IPv4 routes on the lab but the static route will not work with interface direct connected command on fast ethernet. This will only work with Point to Point interface type.
Remove Static route configuration and add as below:
Add routing as:
R0:
ipv6 route 3000:300:AB:FFF::/64 3000:200:AB:FFF:2D0:97FF:FEE9:D202
R1:
ipv6 route 3000:100:AB:FFF::/64 3000:200:AB:FFF:20A:F3FF:FE4A:7E02
Here, is the guide, how to configure static or default on Ipv6: https://networklessons.com/ipv6/how-to-configure-ipv6-static-route
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
11 Replies 11
luis_cordova
Hi @johndexters1100
Compress your exercise (winzip) and attach it to check.
Here @luis_cordova :)
Hi @johndexters1100
For some reason, PacketTracer sends the packets from the routers as multicast with the crossover cable connected.
This changes when using a serial cable.
It may be due to a PT bug.
I attached the exercise with some changes I made.
Thank you @luis_cordova
But it seems that we have different version of packet tracer that making it not compatible with my version. What's your version of packet tracer?
Hi @johndexters1100
My version is the latest (7.2.2)
You can download this version from Netacad
Thanks @luis_cordova
BTW, while I'm downloading the latest version, did you change the crossover to serial DCE?
Hi @johndexters1100
Yes
Oh okay @luis_cordova
The given activity to us is the crossover is needed in the given topology to me.
But, thank you very much and I appreciate your help. :)
I
Deepak Kumar
Add routing as:
R0:
R1:
Deepak Kumar,
Thank you @Deepak Kumar :)
Your welcome! If this is worked for you then accept the solution and vote it.
Deepak Kumar,
