Simple Network & Aggregate address command
news2010a
Level 3
Level 3
Imagine someone tells me "I want to advertise network 150.33.36.0/23" via BGP.
Then I am given the following config regarding this:
router bgp 100
network 150.33.36.0 mask 255.255.255.0
aggregate-address 150.33.36.0 255.255.254.0 summary-only
My conclusion:
I do not believe that the above is right.
I think this should be:
router bgp 100
network 150.33.36.0 mask 255.255.254.0
Can someone confirm if the first configuration could work?
Giuseppe Larosa
Hello Marlon,
the right configuration is the first one because the aggregate command creates a /23 if one component route, more specific route is present in the BGP table. the network command may provide that component route if prefix 150.33.36.0/24 is known in some way in the IP routing table.
note a component more specific route has to be in the BGP table by any means: passed by another BGP peer or locally injected by network command
One command that can influence BGP behaviour for network command  is auto-summary
with auto-summary disabled ( it should be the default nowdays) an exact match is required for a network command to be effective
for this reason configuration 2 may be  wrong:
the network command would match only if 150.33.36.0/23 exists in the IP routing table, but if it already exists the aggregate command would be useless!
when auto-summary is enabled the network command can match more specific routes, but major networks are advertised in this case 150.33/16 would be advertised to a neighbor in another major network.
Hope to help
Giuseppe
Giuseppe Larosa
Hello Marlon,
Hope to help
Giuseppe
