Two Default routes
anitachoi3
Hi Expert,
Attached please find the existing network block diagram and relevant config for your reference.
HK: router to ISP - A
router ospf 192
network 192.168.0.0 0.0.255.255 area 0
network 192.168.10.0 0.0.255.255 area 0
network 192.168.20.0 0.0.255.255 area 0
redistribute bgp 192 metric-type 1 subnets route-map FROM-ISP
router bgp 192
neighbor 172.16.10.1 remote-as 172
neighbor 172.16.10.1 distribute-list 1 out
access-list 1 permit 192.168.0.0 0.0.255.255
access-list 1 permit 192.168.10.0 0.255.255.255
access-list 1 permit 192.168.20.0 0.255.255.255
ip access-list standard DEF-ROUTE
permit 0.0.0.0
route-map FROM-ISP permit 10
match ip address DEF-ROUTE
set metric 1000
TWK: router to ISP - A
router ospf 192
network 192.168.110.0 0.0.255.255 area 0
network 192.168.120.0 0.0.255.255 area 0
router bgp 192
neighbor 172.16.110.1 remote-as 172
neighbor 172.16.110.1 distribute-list 1 out
access-list 1 permit 192.168.110.0 0.255.255.255
access-list 1 permit 192.168.120.0 0.255.255.255
permit 0.0.0.0
set metric 1000
Question:
1. I would like to control the traffic in/out. If traffic is out from HK, the return traffic is expected to come into HK links.  If traffic is out from TW, the return traffic is expected to come into TW links. It means that where is out, where is in.
In the OSPF, there is on backbond area and there are two default routes (one from HK, other from TW). how can I achieve it?
2. There is no inter-connection between two BGP routers which one is in HK, other is in TW. Any technical issue will be arisen in the future?
Rdgs
Hello Anita,
the default-information originate command supports a route-map option
the route-map can be used to check the presence of the BGP 0.0.0.0/0 coming from the expected BGP next-hop
router ospf 192
default-information originate metric-type 1 route-map check-bgp
ip prefix-list only-default permit 0.0.0.0/0
access-list 25 0.0.0.0
access-list 11 host a.b.c.d
route-map check-bgp permit 20
match ip address 25
match ip next-hop 11
set metric 10
where a.b.c.d is the expected BGP next-hop
I have used this approach some years ago and it was successful by using O E1 routes each internet router becomes the exit point for all those networks that see a best path through it.
>> Furthermore, there is one 20M ME inter-connect to two sites where are running on OSPF with single area design only
this is fine.
Hope to help
Giuseppe
Giuseppe Larosa
Hello Anita,
first note:
to generate a default in OSPF you need to use default-information originate you can use a route-map that checks the BGP 0.0.0.0/0 route but you cannot redistribute it into OSPF as a normal prefix
you are right to use O E1 type route.
it is not clear to me if HK and TW have a connection or are separate networks
hope to help
Giuseppe
Dear Giuseppe,
The configuration would be amended as below
router ospf 192
Regarding your message, "you cannot redistribute it into OSPF as a normal prefix". how to inform OSPF (routing protocol) that the "default route" is in BGP?
In addition, "O E1 type route" approach is copied from preceding router. I do not have any idea about it. Grateful if you would enlighten me about the advantage of using "O E1 type route".
Furthermore, there is one 20M ME inter-connect to two sites where are running on OSPF with single area design only.
rdgs
Hello Anita,
router ospf 192
match ip address 25
set metric 10
this is fine.
Hope to help
Giuseppe
