Simple OSPF configuration
beiriger
I setup a simple OSPF configuration but I am not seeing the OSPF route when doing a show ip route. The show ip ospf neighbor command is working correctly. Here is the configuration I setup http://www.cisco.com/en/US/tech/tk365/technologies_configuration_example09186a0080094057.shtml
vijayasankar
Level 4
Level 4
Kindly provide the exact configurations in your routers (show run output) along with the outputs of "show ip ospf neighbor" and "show ip route".
-VJ
jackyoung
Level 6
Level 6
Do you mean you cannot find the 'loopback interface' routes at the routers ? If it appears, it may be the host route generated by the PPP, please check the description in the link at bottom.
Or please provide the config.
Hope this helps.
sachinraja
Level 9
Level 9
The first thing you have to check is the Topology database on your router.. this is the first step for any ospf troubleshooting.. can you give a "show ip ospf database" and see if the entry is there ? Only if it in the database, the router will compute the path in the routing table !!!! As VJ told, can you also give us more details ?? Are there any prefix list or route-maps filtering any routes ???
Raj
mheusinger
Level 10
Level 10
there seems to be a bit missing in the example config given following your link.
Router1
interface Loopback0
ip address 3.3.3.3 255.255.255.255
interface Serial0
ip address 1.1.1.2 255.255.255.0
router ospf 1
network 1.1.1.0 0.0.0.255 area 0
network 3.3.3.3 0.0.0.0 area 0
Router2
interface Loopback0
ip address 2.2.2.2 255.255.255.255
interface Serial0
ip address 1.1.1.1 255.255.255.0
clockrate 2000000
router ospf 1
network 2.2.2.2 0.0.0.0 area 0
The two additional network statements will include the loopback networks into OSPF and announce them to the neighboring router.
Just following the original config will not give you ospf routes, because OSPF will only announce 1.1.1.0/24 and this network is already in the routing table with better administrative distance, namely being directly connected.
Alternatively you can also configure
router ospf 1
redistribute connected subnets
To include the loopback networks in OSPF updates.
Hope this helps! Please use the rating system.
Regards, Martin
