07-09-2010 08:18 AM - edited 03-04-2019 09:01 AM
Hello all,
I am adding a 1941 router to our network to test a new comcast cable circuit with a /29 static block that they sold us. The only config I have done to the router is the interfaces and the default route. When I change my pc's default gateway to the new router, I can't access anything beyond the router. From the router I can ping any internet host succesfully. Traceroutes don't always complete successfully from the router though. If I hook a pc directly into the cable modem, I can browse the internet. Config of 1941 posted below. Any ideas?
Thank you.
version 15.0
hostname name
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
aaa new-model
aaa authentication login default local
aaa session-id common
no ipv6 cef
ip source-route
ip cef
no ip domain lookup
ip domain name yourdomain.com
ip name-server 68.87.64.150
crypto pki trustpoint TP-self-signed-3735527223
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3735527223
revocation-check none
rsakeypair TP-self-signed-3735527223
crypto pki certificate chain TP-self-signed-3735527223
certificate self-signed 01
quit
license udi pid CISCO1941/K9 sn number
username user privilege 15 secret 5 password
redundancy
interface GigabitEthernet0/0
description Internal LAN
ip address 10.1.9.251 255.255.255.0
ip mask-reply
ip virtual-reassembly
duplex auto
speed auto
no cdp enable
no mop enabled
interface GigabitEthernet0/1
ip address 75.151.154.178 255.255.255.248
ip mask-reply
duplex auto
speed auto
no cdp enable
no mop enabled
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 75.151.154.182
no cdp run
control-plane
line con 0
line aux 0
line vty 0 4
privilege level 15
transport input ssh
line vty 5 15
privilege level 15
transport input ssh
scheduler allocate 20000 1000
end
07-09-2010 08:28 AM
I guess you are missing the NAT rules on the router. Please try the
following:
interface overload
For example, if FastEthernet 0/0 is internet interface and FastEthernet 0/1
is inside interface with 64.1.1.1 and 192.168.1.1 as IP addresses, the
sample configuration would be:
interface fastethernet 0/0
ip nat outside
exit
interface fastethernet 0/1
ip nat inside
exit
access-list 1 permit 192.168.1.0 0.0.0.255
ip nat source list 1 fastethernet 0/0 overload
Hope this helps,
NT
07-09-2010 08:34 AM
At a minimum you need to add ip nat statements to each interface, an overall ip nat statement setting up overload or 1to1 nats, an ACL for the overload nat if you use it and either a CBAC or ZBF firewall setup.
The following is bare bones and uses CBAC, ZBF is the new thing and recommended but for a basic setup this should work Notes are in { }:
ip inspect CBAC tcp {setups CBAC firewall named CBAC that inspects all TCP traffic and allows inbound responses to outbound request, same for next two lines udp and imcp}
ip inspect CBAC udp
ip inspect CBAC icmp
int gi0/0
ip nat inside {says this is NAT inside interface, when traffic goes to an interface with ip nat outside, translate it}
int gi0/1
ip nat outside {says this is NAT outside interface, when traffic goes to an interface with ip nat inside, translate it}
ip inspect CBAC out {says use the CBAC firewall named CBAC when going out
ip nat inside source list 105 interface GigabitEthernet0/1 overload {says when translating from in to out, use the ip of gi0/1 and overload, aka PAT and only nat things in ACL 105}
access-list 105 permit ip 10.0.0.0 0.255.255.255 any {allows 10.0.0.0/8 anywhere in this cases allows said subnet to be nat'd}
Lastly you should apply some sort of ACL to your internet interface in the inbound direction. Usually you might just allow inbound ssh or other management sessions and maybe certain icmp packets. If you end up nat'ing to servers that need external access you would do that here also.
07-09-2010 08:46 AM
That did it, thanks! One note though. It did not take the "ip inspect CBAC out" command.
