Simple Site to Site 2811 VPN config
tteslicko
Maybe I should be calling support..but I dont' think this is a level 1 deal.
Basically this is a cut and paste from 2 lab 2811's with advanced ip. I don't beleive I have a tunnel established here. Can anyone see anything inherently wrong. This is pretty much a cut and paste deal. I've done some troubleshooting but I don't think any packets at all have passed over the tunnel that claims to be up. Just to be given a hint on direction here will be fine. These are back to back 2811's that can ping each other's serial interfaces.
CHESTER_STANDBY#
Building configuration...
crypto pki trustpoint TP-self-signed-3378xxxxxx
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3378xxxxxx
revocation-check none
rsakeypair TP-self-signed-3378xxxxxx
crypto pki certificate chain TP-self-signed-3378xxxxxx
certificate self-signed 01
{truncated}
CA5EE254 C2A3CEA1 B0274F8D 3F919734 D7AB09D3 D18146A7 9DD4A0CF F9AE4F88
C5A33DAE 741AE002 3D9EB4E7 B7611C8C 4260DF4A C54F47C0 A78E
quit
controller T1 0/0/0
framing esf
clock source internal
linecode b8zs
channel-group 0 timeslots 1-24
crypto isakmp policy 1
authentication pre-share
crypto isakmp key Amscan@80G address 10.250.99.2
crypto ipsec transform-set AMSCAN ah-sha-hmac esp-des esp-sha-hmac
mode transport
crypto map RockStar local-address Serial0/0/0:0
crypto map RockStar 1 ipsec-isakmp
set peer 10.250.99.2
match address 101
interface Tunnel1
bandwidth 1544
ip address 10.250.100.1 255.255.255.0
tunnel source 10.250.99.1
tunnel destination 10.250.99.2
crypto map RockStar
interface FastEthernet0/0
description ip vpn lan
ip address 10.120.250.101 255.255.0.0
duplex auto
speed auto
interface Serial0/0/0:0
ip address 10.250.99.1 255.255.255.0
crypto map RockStar
ip classless
ip route 10.10.0.0 255.255.0.0 Tunnel1
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
access-list 101 permit gre host 10.250.99.1 host 10.250.99.2
end
ELMSFORD VPN
ELMSFORD_VPN#sh run
{truncated}
crypto pki trustpoint TP-self-signed-36393xxxxx
subject-name cn=IOS-Self-Signed-Certificate-363xxxxx
rsakeypair TP-self-signed-3639xxxxx
crypto pki certificate chain TP-self-signed-36393xxxxxx
6D201AA9 BE741CAD 0A57F073 D5239E4F F820EAB8 C3633F93 EC8DD543 84B95CE9
5790CCB6 E4CED486 EF489A5F E6A59A1F 8FB13666 20EE9B
quit
controller T1 0/0/0
framing esf
linecode b8zs
controller T1 0/1/0
framing esf
linecode b8zs
lifetime 84600
crypto isakmp key Amscan@80G address 10.250.99.1
mode transport
set peer 10.250.99.1
set transform-set AMSCAN
match address 101
interface Tunnel0
bandwidth 1544
ip address 10.250.100.2 255.255.255.0
tunnel source 10.250.99.2
tunnel destination 10.250.99.1
crypto map RockStar
description vpn lan int
ip address 10.10.250.101 255.255.0.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip address 10.250.99.2 255.255.255.0
crypto map RockStar
ip classless
ip route 10.120.0.0 255.255.0.0 Tunnel0
access-list 101 permit gre host 10.250.99.2 host 10.250.99.1
end
On the CHESTER_STANDBY can you assign the transform set to the crypto map that's missing.
Sundar
Sundar
i have done that thanks. I had the tunnel up briefly but I got lost in the weeds and rebooted...and it's gone. Thanks for your help...tomorrow's another day i guess and at least i'm not a contractor out in the feild with it....
Yes a tunnel has been succesfully negotiated. I am not sure why this is but maybe it's supposed to work this way....but when I try pinging the remote ethernet interface...it can't succesfully process the reply that it gets saying that it's not an ip sec packet.
Maybe that's correct????
