Simulating T1 connection in Between two routers
mrahman0302
I am trying to run some test in between two servers. I have two 2811 with T1 card installed. I want to configure T1 on both routers that traffic wiil flow from one server to another server through T1 interface. If anybody can help me on that, would really appreciate. My configuration on both router as follows:
isdn switch-type primary-ni
controller T1 0/2/0
framing esf
linecode b8zs
cablelength short 133
pri-group timeslots 1-24
interface Serial0/2/0:23
no ip address
encapsulation hdlc
isdn protocol-emulate network
no cdp enable
interface Serial0/2/0:23.1
ip address 10.1.1.1 255.255.255.0
mrahman0302
1. need to configure "clock internal" under controller, for one router only.
2. please configure ip address under serial 0/2/0:1, do not use subinterfaces.
3. please re-enable keepalive that are intended and intended for proper operation.
4. You have a mismatch on the netmask on the the serial interface. To make it simpler, just use 255.255.255.0 on both router.
5 Replies 5
Wilson Samuel
Level 7
Level 7
The above configuration shown is for ISDN PRI, however if you want to configure T1 line, the command would be :
no isdn switch-type primary-ni
controller T1 0/2/0
framing esf
linecode b8zs
no pri-group timeslots 1-24
channel-group 1 timeslots 1-24
And then you would require a "T1 Crossover Cable" which can be connected between the two interfaces.
HTH,
Please rate if it helps
Kind Regards,
Wilson Samuel
mrahman0302
Hi Samuel,
Thanks for your reply. I have a question that do I need to configure serial interface, how the traffic will flow from one network to another network. Lets say I want traffic from x.x.x.x network to y.y.y.y network.
mrahman0302
That would be defined by the Routing process, you have basically two choices:
1. Static Routing
2. Dynamic Routing
If you select Static Routing you need to enter the Route statements
If you select a Routing protocol (for dynamic routing) then a suitable routing protocol needs to be configured.
Hope that helps,
Please rate all helpful posts
Kind Regards,
Wilson Samuel
Hi Samuel,
I tried the configuration but I can not communicate to other router. Here is my config:
Router A
controller T1 0/2/0
framing esf
linecode b8zs
interface FastEthernet0/0
ip address dhcp
duplex auto
speed auto
interface Serial0/2/0:1
no ip address
no keepalive
interface Serial0/2/0:1.1
ip address 10.1.1.252 255.255.255.240
router eigrp 1
network 10.0.0.0
auto-summary
Router B
controller T1 0/2/0
framing esf
linecode b8zs
ip address dhcp
duplex auto
speed auto
no ip address
no keepalive
ip address 10.1.1.253 255.255.255.224
router eigrp 1
network 10.0.0.0
network 172.20.0.0
auto-summary
Note : 1. I did configure encapsulation hdlc under serial interface but it doesn't show on the running configuration
2. Serial interface on both router is up.
mrahman0302
