Single homed bgp issue
Cool47
I am looking to safely migrate the default route from edge router to secondary ISP2 with BGP setup. But couldn't be able to create bgp session.
bgp config on 4455-01:
router bgp 100
bgp log-neighbor-changes
router-id 192.168.1.50
neighbor 192.168.1.49 remote-as 300
address-family ipv4 unicast
neighbor 192.168.1.49 activate
neighbor 192.168.1.49 soft-reconfiguration inbound
exit-address-family
Once the bgp session established, planning to advertise the subnet from the edge router and remove ISP1
network 100.x.x.x mask 255.255.255.0
the issue here is route is always taking place to ISP1 and unable to create bgp session.
Could you guide me please.
Thank you.
6 Replies 6
first config route-map with weight (highest weight win) for ISP1
here the router will have two path
ISP1 with highest
ISP2 with lowest weight
then after that you can shut down interface to ISP1
the router will use path via ISP2
Edson A. Hernandez
Show us the BGP configuration on ISP2 for neighbor relationship
 I dont follow you here "But couldn't be able to create bgp session."
 If you have the config:
router bgp 100
exit-address-family
The peering should come up. If you run the command show ip bgp you dont see the neighbor 192.168.1.49 ?
This is a Lab or real  network?  But either way, does the ISP2 has the config to form neighborship with 4451 ?
Cool47
Thank you all for the quick responses, I really appreciated.
Yes, this is tested in lab(working as expected regular router but no ISR4455) and same configuration applied in the production. But it was disaster, the router crashed, rebooted and lost all logs. Based on research I think ISP2 send all routes, but no data to validate it.
Please confirm is that above configuration is sufficient for this requirement or am I missing something here?
Thanks again !!.
share ISP2 BGP configuration to check
shwo us the show bgp ipv4 unicast summary
neighbor 192.168.1.49 soft-reconfiguration inbound <<- this issue, this make Router save all prefix.
instead use
route refresh
https://community.cisco.com/t5/switching/soft-reset-and-route-refresh-in-bgp/td-p/2674389
