single interface multiple VRF
jahilnt10
Is it Possible to have 2 or more VRF tables existing on one single Interface Eth/Serial. If the answer is yes, how do you guys do that.
Harold Ritter
It is certainly possible as long as you can configure the interface with logical subinterface such dot1q, frame-relay. Each subinterface would in turn fall into a specific VRF.
As harold pointed out, each logical interface can be a part of a different interface
It is not possible for a single interface though to be part of more than one VRF forwarding instance.
if you are just talking about route tables, you can always import the routes from another VRF which would be mean you have more than one routing table available :-)
Narayan
HI Narayan / Hritter,
Please provide me the sample end - to - end VRF Configuration with Example setup and Configuration.
I have a challenge of VRF implementation still pending in my JOB.
Pls Help....
Best Regards,
Guru Prasad R
Attched configs might help which i did in my lab
There are no P routers invoved in this as i had very limited routers available to test but it should be good to get a idea
Anyway you should be getting plenty of these in CCO
Narayan
