Site to Site VPN Configuration Problems
After spending almost two days on trying to fix this an issue with getting traffic to flow through a site-to-site VPN. I am reaching out to see if anyone can shed some light on the creation of Site to Site VPN's using Cisco 1941W routers and what I have done wrong.
The two sites are connected via ADSL and myself and the other tech have tried creating the VPN tunnel using Config Professional as well as manually. Nether have worked . Below are our configs. If anyone could have a look and see what we have done wrong we will be estatic. Thank you in advance!
"Coach House" Location:
SWML-CH-RTR01#show run
Building configuration...
Current configuration : 5827 bytes
! Last configuration change at 07:43:35 UTC Thu Mar 8 2012 by t4tech
! NVRAM config last updated at 07:43:35 UTC Thu Mar 8 2012 by t4tech
version 15.1
service password-encryption
hostname SWML-CH-RTR01
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 51200
logging console critical
enable secret 5 $1$OT.V$7heedf7HY7diX3KsvFA0N1
no aaa new-model
service-module wlan-ap 0 bootimage autonomous
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 10.10.2.1 10.10.2.20
ip dhcp excluded-address 10.10.2.101 10.10.2.191
ip dhcp excluded-address 10.10.2.193
ip dhcp pool ccp-pool1
network 10.10.2.0 255.255.255.128
default-router 10.10.2.1
dns-server 10.10.2.1
ip dhcp pool ccp-pool2
network 10.10.2.192 255.255.255.192
default-router 10.10.2.193
dns-server 10.10.2.193
lease infinite
ip domain name name.com.au
ip name-server 203.21.20.20
license udi pid CISCO1941W-N/K9 sn FGL15412391
license boot module c1900 technology-package securityk9
hw-module ism 0
redundancy
controller VDSL 0/0/0
ip ssh version 1
crypto isakmp policy 1
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp key ourkey address 58.6.1.176
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto map SDM_CMAP_1 1 ipsec-isakmp
description Tunnel to SWML HQ from CH
set peer 58.6.1.176
set transform-set ESP-3DES-SHA
match address 100
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description $ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$$FW_OUTSIDE$
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
no mop enabled
interface wlan-ap0
description Service module interface to manage the embedded AP
no ip address
arp timeout 0
no mop enabled
no mop sysid
interface GigabitEthernet0/1
description $ES_LAN$$FW_INSIDE$
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip virtual-reassembly in
ip tcp adjust-mss 1412
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/1.100
description $FW_INSIDE$$ETH-LAN$
encapsulation dot1Q 100
ip address 10.10.2.1 255.255.255.128
ip nat inside
no cdp enable
interface GigabitEthernet0/1.200
encapsulation dot1Q 200
ip address 10.10.2.129 255.255.255.192
ip nat inside
no cdp enable
interface Wlan-GigabitEthernet0/0
description Internal switch interface connecting to the embedded AP
switchport mode trunk
no ip address
interface ATM0/0/0
no ip address
no atm ilmi-keepalive
interface ATM0/0/0.1 point-to-point
pvc 8/35
pppoe-client dial-pool-number 2
interface Ethernet0/0/0
no ip address
shutdown
no fair-queue
interface Vlan1
ip address 10.10.2.193 255.255.255.192
ip nat inside
interface Dialer0
ip address negotiated
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 2
dialer-group 2
ppp authentication chap pap callin
ppp chap hostname dslname@westnet.com.au
ppp chap password 7 removed
ppp pap sent-username dslname@westnet.com.au password 7 removed
no cdp enable
crypto ipsec df-bit clear
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip dns server
ip nat inside source route-map SDM_RMAP_1 interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
ip route 10.10.1.0 255.255.255.0 58.6.1.176
logging trap debugging
logging 10.10.1.11
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 10.10.2.0 0.0.0.127
access-list 1 permit 10.10.2.0 0.0.0.255
access-list 1 permit 10.10.2.128 0.0.0.63
access-list 2 remark CCP_ACL Category=2
access-list 2 permit 10.10.2.128 0.0.0.127
access-list 2 permit 10.10.2.0 0.0.0.127
access-list 2 permit 10.10.2.0 0.0.0.255
access-list 10 permit 10.10.1.11
access-list 100 remark IPSec Rules
access-list 100 permit ip 10.10.2.0 0.0.0.255 58.6.1.0 0.0.0.255
access-list 100 permit ip 10.10.2.0 0.0.0.255 10.10.1.0 0.0.0.255
access-list 100 permit ip 10.10.2.0 0.0.0.127 host 10.10.1.1
dialer-list 1 protocol ip permit
dialer-list 2 protocol ip permit
route-map sd permit 10
route-map SDM_RMAP_1 permit 1
match ip address 2
"HQ" Location:
hostname SWML-HQ-RTR01
clock timezone PCTime 8 0
no ipv6 cef
no ip source-route
ip cef
ip dhcp excluded-address 10.10.1.1 10.10.1.20
ip dhcp excluded-address 10.10.1.101 10.10.1.191
ip dhcp excluded-address 10.10.1.193
network 10.10.1.192 255.255.255.192
default-router 10.10.1.193
dns-server 10.10.1.193
lease infinite
no ip bootp server
crypto pki trustpoint TP-self-signed-191340246
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-191340246
revocation-check none
rsakeypair TP-self-signed-191340246
crypto pki trustpoint test_trustpoint_config_created_for_sdm
subject-name e=sdmtest@sdmtest.com
revocation-check crl
crypto pki certificate chain TP-self-signed-191340246
certificate self-signed 01
30820229 30820192 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
30312E30 2C060355 04031325 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 31393133 34303234 36301E17 0D313131 31323430 34333935
345A170D 32303031 30313030 30303030 5A303031 2E302C06 03550403 1325494F
532D5365 6C662D53 69676E65 642D4365 72746966 69636174 652D3139 31333430
32343630 819F300D 06092A86 4886F70D 01010105 0003818D 00308189 02818100
8383B011 26ACCBF9 1E2CBB79 AE7CA9D8 72F553DF DAC8369D 67D8A46F 9C726DD2
FE1F3B8C 0DFB3506 943F8432 E764523E 867B9396 DFA0F67D E8B9F84D 0AFDD4CD
D6F393C9 3054AADD DA253DE8 041E55F5 C43FCA7D D35932EA 52A7876D 14F4C6A5
1BD9E369 58D387B0 3DCA3708 3329D21A 103A0B12 B7F1EF9C 93ECC557 B54C960B
02030100 01A35330 51300F06 03551D13 0101FF04 05300301 01FF301F 0603551D
23041830 16801483 01F42DFD 84AECE63 2CAD003F E316F7E3 C7A1E230 1D060355
1D0E0416 04148301 F42DFD84 AECE632C AD003FE3 16F7E3C7 A1E2300D 06092A86
4886F70D 01010505 00038181 006B7FBA 64522E2A 355BE979 33E4D5D9 6B82738F
09F67EE6 64DC79D0 40EF937D B7F39C4E AF4894AA 60FF3849 08F4C5D5 57C5FE39
72E28954 9AEBBBFB FB340475 140A75D3 24A7DC66 E10B62B0 D3E92339 A8680A2B
D0E954D0 72F6263D 14A7DBF0 B3B90512 0F77FFAC ECD080A4 7DC5139A 13E74309
7E21F365 8C3F41BE 0D84A236 01
       quit
crypto pki certificate chain test_trustpoint_config_created_for_sdm
license udi pid CISCO1941W-N/K9 sn FGL154820D0
hw-module ism 0
vtp mode client
redundancy
ip tcp synwait-time 10
ip ssh time-out 60
ip ssh authentication-retries 2
ip ssh version 1
class-map type inspect match-any ccp-cls-icmp-access
match protocol icmp
match protocol tcp
match protocol udp
class-map type inspect match-all SDM_GRE
match access-group name SDM_GRE
encr 3des
hash md5
group 2
crypto isakmp key ourkey address 203.59.231.119
description Tunnel to SWML CH from HQ
set peer 203.59.231.119
match address 103
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
shutdown
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
duplex auto
speed auto
no mop enabled
interface wlan-ap0
no ip address
no ip unreachables
ip flow ingress
arp timeout 0
no mop enabled
no mop sysid
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
duplex auto
speed auto
no mop enabled
ip address 10.10.1.1 255.255.255.128
ip nat inside
no cdp enable
ip address 10.10.1.129 255.255.255.192
ip nat inside
no cdp enable
no ip address
interface ATM0/0/0
no ip address
pvc 8/35
no ip address
shutdown
no fair-queue
interface Vlan1
ip address 10.10.1.193 255.255.255.192
ip helper-address 10.10.1.11
no ip redirects
ip flow ingress
ip nat inside
interface Dialer0
description $FW_OUTSIDE$
ip address 192.168.0.10 255.255.255.0
no ip redirects
ip mtu 1452
ip flow ingress
no cdp enable
interface Dialer2
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 2
dialer-group 2
ppp chap hostname name@westnet.com.au
ppp pap sent-username name password 7 removed
no cdp enable
ip http server
ip dns server
ip nat inside source static tcp 10.10.1.11 25 interface Dialer2 25
ip nat inside source static tcp 10.10.1.11 47 interface Dialer2 47
ip nat inside source static tcp 10.10.1.11 1723 interface Dialer2 1723
ip nat inside source static tcp 10.10.1.11 443 interface Dialer2 443
ip nat inside source static tcp 10.10.1.11 993 interface Dialer2 993
ip nat inside source static tcp 10.10.1.11 80 interface Dialer2 80
ip nat inside source static tcp 10.10.1.11 3389 interface Dialer2 3088
ip nat inside source route-map SDM_RMAP_1 interface Dialer2 overload
ip nat inside source route-map SDM_RMAP_2 interface Dialer2 overload
ip route 0.0.0.0 0.0.0.0 Dialer2
ip route 10.10.2.0 255.255.255.0 203.59.231.119
ip access-list extended ALLIP
remark ALL ip
remark CCP_ACL Category=1
permit ip any any
ip access-list extended OUTIP
remark OUTIP
remark OUT
permit ip any any
ip access-list extended SDM_GRE
permit gre any any
logging 10.10.1.11
access-list 1 permit 10.10.1.0 0.0.0.127
access-list 1 permit 10.10.1.0 0.0.0.255
access-list 1 permit 10.10.1.128 0.0.0.63
access-list 2 permit 10.10.1.128 0.0.0.127
access-list 100 remark CCP_ACL Category=4
access-list 100 permit ip 10.10.1.128 0.0.0.63 10.10.2.128 0.0.0.63 log
access-list 100 permit ip 10.10.1.128 0.0.0.63 203.59.231.0 0.0.0.255 log
access-list 101 remark CCP_ACL Category=18
access-list 101 deny   ip 10.10.1.128 0.0.0.63 10.10.2.128 0.0.0.63
access-list 101 deny   ip 10.10.1.0 0.0.0.255 124.148.218.0 0.0.0.255 log
access-list 101 deny   ip 10.10.1.0 0.0.0.255 10.10.3.0 0.0.0.255 log
access-list 101 deny   ip 10.10.1.0 0.0.0.255 10.10.2.0 0.0.0.255 log
access-list 101 permit ip 10.10.1.0 0.0.0.255 any
access-list 101 permit ip 10.10.1.0 0.0.0.127 any
access-list 101 permit ip 10.10.1.128 0.0.0.63 any
access-list 102 remark CCP_ACL Category=6
access-list 102 deny   ip 10.10.1.128 0.0.0.63 10.10.2.128 0.0.0.63
access-list 102 remark IPSec Rule
access-list 102 permit ip 10.10.1.128 0.0.0.63 10.10.2.128 0.0.0.63
access-list 103 remark IPSec Rules
access-list 103 permit ip 10.10.1.0 0.0.0.255 10.10.2.0 0.0.0.255 log
access-list 103 permit ip 10.10.1.0 0.0.0.255 203.59.231.0 0.0.0.255 log
access-list 103 permit ip 10.10.1.0 0.0.0.127 host 10.10.2.1
no cdp run
match ip address 101
route-map SDM_RMAP_2 permit 1
match ip address 102
andrew.prince
Level 10
Level 10
At first glance - you are using IP DHCP for your WAN connection at boths sites, how can they build a tunnel, if both endpoints can change at any time?  Have you confirmed that the IP addresses you have specified are the correct ones?
Neeraj Arora
Level 3
Level 3
Nicholas,
Two changes that I would suggest in your config:
1. In the crypto ACL, you don't need to add the statement for allowing the traffic going towards VPN peer like "access-list 100 permit ip 10.10.2.0 0.0.0.255 58.6.1.0 0.0.0.255" & "access-list 103 permit ip 10.10.1.0 0.0.0.255 203.59.231.0 0.0.0.255 log". so remove this statement from the ACL
2. In SWML-CH-RTR01 router, the traffic which is supposed to traverse across the tunnel is not denied from being NAT. you'd have to use another extended ACL for the route-map SDM_RMAP_1 like its being done on the other router
Hope the above steps helps. In case you still face issues, do paste the output of:
sh ip nat translation
sh crypto isa sa
sh crypto ipsec sa
sh ip route
sh access-list
