1841 cold always boots to ROMMON
CiscoNordeast
Hi, we have 55 of the 1841 routers here, and one of them always boots to ROMMON from a very cold (down 1 hour or more) start.  The image on all 55 is c1841-ipbasek9-mz.124-24.T4.bin.  32 MB Cisco brand flash.  Here's what's been done thus far:
In ROMMON changed to 0x2102.  Then 'reset' and the image boots fine.  Change config-reg to 0x2102.  Save config.  Reload and image boots fine again.  Wait an hour or more and boots to ROMMON.
Boot from ROMMON to USBflash0:   Format the CF then copy over the bin file.  Change to 0x2102 and save. Reload and image boots fine again. Wait an hour or more and boots to ROMMON.
Swapped CF with another unit.  Again, works fine to reload, but shut down and restart an hour or more later and boots to ROMMON.  Format this CF and copy over image while on router.  Image boots fine.  Wait an hour or more and boots to ROMMON.
In each case of very cold start the configuration register has reverted to 0x0 {why it boots to ROMMON}
Tried dx mode with 0x8001.  Nothing seen that is unusual to me, but I'm not an expert by any means.
It doesn't seem to a CF card problem, but could be a connection to the CF card and then something behind that.
Here is the output of diagnostic boot mode:
Cisco 1841 (revision 7.0) with 116736K/14336K bytes of memory.
Processor board ID FTX1231W0JA
2 FastEthernet interfaces
2 Low-speed serial(sync/async) interfaces
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
31360K bytes of ATA CompactFlash (Read/Write)
Configuration register is 0x8001
Router>
System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
Copyright (c) 2006 by cisco Systems, Inc.
Initializing cache
Initializing TLB and required TLB entries
Reading monitor variables from NVRAM
Init Rommon Upgrade NVRAM Vars
Init Rommon Upgrade startPLD version 0x10
GIO ASIC version 0x127
Reset IO
Enabling interrupts
Reading cookie
Initializing main memory
Sizing NVRAM
Initializing PCI subsystem
Exiting init
c1841 platform with 131072 Kbytes of main memory
Main memory is configured to 64 bit mode with parity disabled
Readonly ROMMON initialized
program load complete, entry point: 0x8000f000, size: 0xcb80
program load complete, entry point: 0x8000f000, size: 0x1a4e2e8
Stack pointer       : 0x87FFFF80
monstack            : 0x8000EFC0
monra               : 0xBFC016B4
edata : 0x800259A0
magic : 0xFEEDFACE
memsize             : 0x08000000
uncomp_size         : 0x034AE128
comp_size           : 0x01A37931
STACK_BYTES         : 0x00008000
COPY_CODE_BUF       : 0x00000800
_end                : 0x8004E240
comp_checksum       : 0xB3FD84DA
uncomp_checksum     : 0xB12F46D8
Self decompressing the image : ################################################################################################################################################# [OK]
Source elf_hdr->e_shnum = 0x00000010
Setting up to copy ELF section 0x00000001
to image_info section 0x00000000
sh_name = 0x0000000B
sh_type = 0x00000001
sh_flags = 0x00000007
sh_addr = 0x8000F000
sh_offset = 0x00000060
sh_size = 0x01FB17A4
sh_link = 0x00000000
sh_info = 0x00000000
sh_addralign = 0x00000020
sh_entsize = 0x00000000
Setting up to copy ELF section 0x00000002
to image_info section 0x00000001
sh_name = 0x00000011
sh_flags = 0x00000006
sh_addr = 0x81FC07A4
sh_offset = 0x01FB1804
sh_size = 0x00006324
sh_addralign = 0x00000004
Setting up to copy ELF section 0x00000003
to image_info section 0x00000002
sh_name = 0x00000015
sh_addr = 0x81FC6AC8
sh_offset = 0x01FB7B28
sh_size = 0x00000C78
Setting up to copy ELF section 0x00000005
to image_info section 0x00000003
sh_name = 0x00000022
sh_flags = 0x00000002
sh_addr = 0x82000000
sh_offset = 0x01FF1060
sh_size = 0x00B52378
sh_addralign = 0x00000008
Setting up to copy ELF section 0x00000006
to image_info section 0x00000004
sh_name = 0x0000002A
sh_flags = 0x00000003
sh_addr = 0x82B52378
sh_offset = 0x02B433D8
sh_size = 0x000A3F34
Setting up to copy ELF section 0x00000007
to image_info section 0x00000005
sh_name = 0x00000034
sh_addr = 0x82BF62AC
sh_offset = 0x02BE730C
sh_size = 0x0000D600
Setting up to copy ELF section 0x00000008
to image_info section 0x00000006
sh_name = 0x0000003D
sh_addr = 0x82C038AC
sh_offset = 0x02BF490C
sh_size = 0x0006E148
Setting up to copy ELF section 0x00000009
to image_info section 0x00000007
sh_name = 0x00000049
sh_addr = 0x82C71A00
sh_offset = 0x02C62A60
sh_size = 0x0054E3A8
Setting up to copy ELF section 0x0000000A
to image_info section 0x00000008
sh_name = 0x0000004F
sh_addr = 0x831BFDC0
sh_offset = 0x031B0E20
sh_size = 0x00000010
sh_addralign = 0x00000001
Setting up to copy ELF section 0x0000000B
to image_info section 0x00000009
sh_name = 0x00000056
sh_flags = 0x10000003
sh_addr = 0x831BFDE0
sh_offset = 0x031B0E40
sh_size = 0x000004F8
sh_addralign = 0x00000010
cpu type                   : 0x00000006
image_info.entry_point   = 0x80015F40
image_info.section_count = 0x0000000A
image_info.monstack      = 0x8000EFC0
image_info.monra         = 0xBFC016B4
image_info.param0        = 0x00000002
image_info.param1        = 0x00000000
image_info.param2        = 0x8000C508
image_info.param3        = 0x8000F000
Section Index = 0x00000000
    source    = 0x8004E3A0
    dest      = 0x80015F40
    bytes     = 0x01FB17A4
Section Index = 0x00000001
    source    = 0x81FFFB44
    dest      = 0x81FC76E4
    bytes     = 0x00006324
Section Index = 0x00000002
    source    = 0x82005E68
    dest      = 0x81FCDA08
    bytes     = 0x00000C78
Section Index = 0x00000003
    source    = 0x8203F3A0
    dest      = 0x82006F40
    bytes     = 0x00B52378
Section Index = 0x00000004
    source    = 0x82B91718
    dest      = 0x82B592B8
    bytes     = 0x000A3F34
Section Index = 0x00000005
    source    = 0x82C3564C
    dest      = 0x82BFD1EC
    bytes     = 0x0000D600
Section Index = 0x00000006
    source    = 0x82C42C4C
    dest      = 0x82C0A7EC
    bytes     = 0x0006E148
Section Index = 0x00000007
    source    = 0x82CB0DA0
    dest      = 0x82C78940
    bytes     = 0x0054E3A8
Section Index = 0x00000008
    source    = 0x831FF160
    dest      = 0x831C6D00
    bytes     = 0x00000010
Section Index = 0x00000009
    source    = 0x831FF180
    dest      = 0x831C6D20
    bytes     = 0x000004F8
Smart Init is enabled
smart init is sizing iomem
  ID            MEMORY_REQ         TYPE
                0X003AA110 public buffer pools
                0X00211000 public particle pools
                0X00020000 Crypto module pools
0X0013          0X00035000 Card in slot 0
                0X000021B8 Onboard USB
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Allocating additional 5271784 bytes to IO Memory.
PMem allocated: 119537664 bytes; IOMem allocated: 14680064 bytes
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, 1841 Software (C1841-IPBASEK9-M), Version 12.4(24)T4, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Fri 03-Sep-10 03:51 by prod_rel_team
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Is there a capacitor slow draining somewhere?  Appreciate any assistance.
7 Replies 7
paolo bevilacqua
Try updating rommon. If still trouble, RMA the unit (requires a support contract).
Updated the ROM monitor to  C1841_RM2.srec.124-13r.T5.  {USB makes this quick and easy}  There is no change in the behavior.
Noticed also that this unit alerts to possible non-genuine WIC in 0-1-1.  But the 2A/S was direct from Cisco.  Remove the WIC and it still gives the same alert on boot.
Finally, noticed that boot to ROMMON will occur right after all power is removed - power cord unplugged.  So perhaps a battery issue?
We'll need to consider repairs, as you advised.  Thanks for your response.
Leo Laohoo
You can't boot from USB because your ROMmon is not running the version which support booting at USB.  Like what Paolo said, upgrade to 12.4(13r)T5.
I suspect you do not have enough DRAM.  According to the Cisco Download Software page for the 1841, to run this IOS, you need 192 DRAM and 64 Flash.  Both cases, you don't have enough of.
Turns out that it was able to boot successfully from USB.
As to possible insufficient memory, the same configuration (hdwr + ios) runs ok on another 20 units.
Appreciate the input; issues to be considered.
Then you got me stumped.  If this is the only unit that's having this problem then I guess you could be facing a hardware issue.
jszapipes
Have you tried adding to your start up config?
"boot system flash:your ios version.bin"
Neeraj Arora
Level 3
Level 3
I do agree with the last response of configuring a boot statementin the configuration
"boot system flash flash:c1841-ipbasek9-mz.124-24.T4.bin"   .... yes it has two flash kw in it...
But the behaviour you've mentioned does not point towards a config fault, instead I would give two possible reasons:
- there is a battery present in routers which is supposed to last router's life time (which we safely can say is somewhere from 6-10 yrs) but it can sometime fail
- As you have observered that after taking the power chord out, this issue happens. It could be possible when the power is turned on, the inrush current could possible reset the ASIC which holds the config register value causing this peculiar behaviour
In both the cases, your best bet is to get the router replaced if it is under a valid support contract or contact the reseller from whom you bought this
Neeraj
