Site to Site VPN Status Active but can't ping remote LAN
chris.fletcher1
I have to remote LAN's that I'm trying to connect.
At the end of one I have an RV082 small business router and at the other one, I've got an RV180 small business router.
I've made sure that the encryption and authentication match with what I've got on my 2851.
It appears as though the tunnel is created properly and is active but I cannot ping from the 2851 to either of the other two routers.
IP address below are of course fake.
Here's the output from sh crypto isakmp sa
IPv4 Crypto ISAKMP SA
dst             src             state          conn-id status
10.10.10.10    20.20.20.20    QM_IDLE           1029 ACTIVE
10.10.10.10    30.30.30.30    QM_IDLE           1028 ACTIVE
Here's the output from sh crypto ipsec sa
    Crypto map tag: vpnset, local addr 10.10.10.10
   protected vrf: (none)
   local  ident (addr/mask/prot/port): (192.168.0.0/255.255.252.0/0/0)
   remote ident (addr/mask/prot/port): (192.168.4.0/255.255.255.0/0/0)
   current_peer 20.20.20.20 port 500
     PERMIT, flags={origin_is_acl,}
    #pkts encaps: 4109, #pkts encrypt: 4109, #pkts digest: 4109
    #pkts decaps: 3922, #pkts decrypt: 3922, #pkts verify: 3922
    #pkts compressed: 0, #pkts decompressed: 0
    #pkts not compressed: 0, #pkts compr. failed: 0
    #pkts not decompressed: 0, #pkts decompress failed: 0
    #send errors 6, #recv errors 0
     local crypto endpt.: 10.10.10.10, remote crypto endpt.: 20.20.20.20
     path mtu 1500, ip mtu 1500, ip mtu idb GigabitEthernet0/0
     current outbound spi: 0x0(0)
     PFS (Y/N): N, DH group: none
     inbound esp sas:
     inbound ah sas:
     inbound pcp sas:
     outbound esp sas:
     outbound ah sas:
     outbound pcp sas:
   local  ident (addr/mask/prot/port): (192.168.1.0/255.255.255.0/0/0)
     PERMIT, flags={}
    #pkts encaps: 11349, #pkts encrypt: 11349, #pkts digest: 11349
    #pkts decaps: 14169, #pkts decrypt: 14169, #pkts verify: 14169
    #send errors 0, #recv errors 0
     current outbound spi: 0xD1CEC2A(219999274)
     PFS (Y/N): Y, DH group: group1
     inbound esp sas:
      spi: 0x1F851ADD(528816861)
        transform: esp-3des esp-sha-hmac ,
        in use settings ={Tunnel, }
        conn id: 2327, flow_id: Onboard VPN:327, sibling_flags 80000046, crypto map: vpnset
        sa timing: remaining key lifetime (k/sec): (4545766/1711)
        IV size: 8 bytes
        replay detection support: Y
        Status: ACTIVE
     inbound ah sas:
     inbound pcp sas:
     outbound esp sas:
        conn id: 2328, flow_id: Onboard VPN:328, sibling_flags 80000046, crypto map: vpnset
        sa timing: remaining key lifetime (k/sec): (4541630/1711)
        IV size: 8 bytes
        Status: ACTIVE
     outbound ah sas:
     outbound pcp sas:
   remote ident (addr/mask/prot/port): (192.168.10.0/255.255.255.0/0/0)
   current_peer 30.30.30.30 port 500
    #pkts encaps: 0, #pkts encrypt: 0, #pkts digest: 0
    #pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0
     local crypto endpt.: 10.10.10.10, remote crypto endpt.: 30.30.30.30
     inbound esp sas:
     inbound ah sas:
     inbound pcp sas:
     outbound esp sas:
     outbound ah sas:
     outbound pcp sas:
     PERMIT, flags={}
     current outbound spi: 0x7730C889(1999685769)
     inbound esp sas:
      spi: 0x96D989C7(2530838983)
        conn id: 2329, flow_id: Onboard VPN:329, sibling_flags 80000046, crypto map: vpnset
        sa timing: remaining key lifetime (k/sec): (4428983/2778)
        IV size: 8 bytes
        Status: ACTIVE
     inbound ah sas:
     inbound pcp sas:
     outbound esp sas:
        conn id: 2330, flow_id: Onboard VPN:330, sibling_flags 80000046, crypto map: vpnset
        IV size: 8 bytes
        Status: ACTIVE
     outbound ah sas:
     outbound pcp sas:
I've got a Cisco 2851 Router configured as follows:
Building configuration...
Current configuration : 4677 bytes
! Last configuration change at 17:15:44 UTC Mon Oct 10 2016
version 15.1
service password-encryption
hostname ORIONRT01
boot-start-marker
boot-end-marker
enable secret 4 InTtoRkWqyUp3aameBRcn5XPvgoeWpqm4eGwGnsdKHc
no aaa new-model
dot11 syslog
ip source-route
ip cef
ip name-server 192.168.1.55
no ipv6 cef
voice-card 0
license udi pid CISCO2851 sn FTX1226A1PU
archive
 log config
  hidekeys
redundancy
crypto isakmp policy 10
 encr 3des
 authentication pre-share
crypto isakmp key supersecretkey address 20.20.20.20
crypto isakmp key supersecretkey address 30.30.30.30
crypto ipsec transform-set vpnset esp-3des esp-sha-hmac
crypto map vpnset 10 ipsec-isakmp
 set peer 20.20.20.20
 set transform-set vpnset
 match address 101
crypto map vpnset 20 ipsec-isakmp
 set peer 30.30.30.30
 match address 102
interface GigabitEthernet0/0
 description WAN
 ip address 10.10.10.10 255.255.255.248
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
 crypto map vpnset
interface GigabitEthernet0/1
 description LAN
 ip address 192.168.1.1 255.255.252.0 secondary
 ip address 192.168.1.6 255.255.252.0
 ip nat inside
 duplex auto
 speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source route-map nonat interface GigabitEthernet0/0 overload
ip nat inside source static tcp 192.168.1.4 80 10.10.10.10 80 extendable
".. lots more static NAT rules "
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 101 permit ip 192.168.0.0 0.0.3.255 192.168.4.0 0.0.0.255
access-list 102 permit ip 192.168.0.0 0.0.3.255 192.168.10.0 0.0.0.255
access-list 110 deny   ip 192.168.0.0 0.0.3.255 192.168.4.0 0.0.0.255
access-list 110 permit ip 192.168.0.0 0.0.3.255 any
access-list 115 deny   ip 192.168.0.0 0.0.3.255 192.168.10.0 0.0.0.255
access-list 115 permit ip 192.168.0.0 0.0.3.255 any
access-list 120 permit ip 192.168.4.0 0.0.0.255 192.168.0.0 0.0.3.255
access-list 130 permit ip 192.168.10.0 0.0.0.255 192.168.0.0 0.0.3.255
route-map nonat permit 10
 match ip address 110 115
Thanks for the additional information which does clarify the issue quite nicely. The issue is that you are pinging from the 2851. By default when the router pings it will make the source address of the packet to be the IP of the outbound interface. So the source address of your ping is 10.10.10.10. But the crypto map of the router does not identify any traffic with source address of 10.10.10.10 to be carried through the tunnel.
The easy way to fix this is that in your ping you specify the source address to be Gig0/1.
Rick
Rick
7 Replies 7
Richard Burts
We do not know enough yet to accurately identify the source of the issue. Here are some observations and questions that I hope may help us more forward in solving this issue.
- the output shows that the tunnel to 20.20.20.20 is passing traffic in both directions and as such we can mostly assume that this VPN tunnel is working correctly.
- the output shows that the tunnel to 30.30.30.30 is not passing traffic in either direction. The tunnel comes up but does not pass traffic. This suggests that the crypto parameters are probably correct but that there is some issue with identifying and processing the IP traffic to be carried through the tunnel.
- can you clarify how you are testing? are you pinging from the router itself or from something connected to the router? What address on the remote side are you pinging to?
Rick
Rick
Hi Richard thanks for the reply.
I am pinging from the 2851.
The 192.168.4.0 network is on the inside of 20.20.20.20.
I tried pinging various hosts on that network from the 2851.
Here's an output showing ping and traceroute
ORIONRT01#ping 192.168.4.1
Sending 5, 100-byte ICMP Echos to 192.168.4.1, timeout is 2 seconds:
Success rate is 0 percent (0/5)
ORIONRT01#ping 192.168.4.200
Sending 5, 100-byte ICMP Echos to 192.168.4.200, timeout is 2 seconds:
ORIONRT01#tracero
ORIONRT01#traceroute 192.168.4.1
Tracing the route to 192.168.4.1
VRF info: (vrf in name/id, vrf out name/id)
  1 192.168.0.1 4 msec 8 msec 8 msec
  2  *  *  *
I'm not too worried about 30.30.30.30 yet. I'm more worried about making the other tunnel work first.
Rick
Rick
Richard, thank you so much for clarifying this for me.
It does indeed ping successfully when specifying the source interface.
I am glad that my suggestion did provide a solution to the problem with pinging to the remote site. I continue to believe that there is still a problem with the tunnel to 30.30.30.30 which needs to be resolved.
Rick
Rick
Hi Richard and thanks for the follow up. I was able to get that tunnel up as well. Thank you for all your help.
Thanks for the update. I am glad that you were able to get the other tunnel up. So now both VPNs are working as expected?
Rick
Rick
