site to site vpn with NAT
junshah22
I am configuring site-to-site vpn with cisco routers, both ends have Live IPs,
I am following up the following document for creating the vpn, In this case VPN tunnel works fine, but the internet service stops on both ends,
I have private network inside the router and vlans are configured, Vlans must be natted to get access of internet service,
when I remove the statements, ip nat inside and ip nat outside from the inside and outside interfaces,, my tunnel goes UP and works fine,, but as soon I add the NAT commands to the respective interfaces, the tunnel goes down but internet service starts,,,
The author havn't mentioned any NAT statement,,
1. Create Internet Key Exchange (IKE) key policy. The policy used for our case is policy number 9, because this policy requires a pre-shared key.
Router(config)#crypto isakmp policy 9
Router(config-isakmp)#hash md5
Router(config-isakmp)#authentication pre-share
2. Setup the shared key that would be used in the VPN,
Router(config)#crypto isakmp key VPNKEY address XXX.XXX.XXX.XXX
where,
VPNKEY is the shared key that you will use for the VPN, and remember to set the same key on the other end.
XXX.XXX.XXX.XXX the static public IP address of the other end.
3. Now we set lifetime for the IPSec security associations,
Router(config)#crypto ipsec security-association lifetime seconds YYYYY
where YYYYY is the associations lifetime in seconds. It is usually used as 86400, which is one day.
4. Configure an extended access-list to define the traffic that is allowed to be directed through the VPN link,
Router(config)#access-list AAA permit ip SSS.SSS.SSS.SSS WIL.DCA.RDM.ASK DDD.DDD.DDD.DDD WIL.DCA.RDM.ASK
where,
AAA is the access-list number
SSS.SSS.SSS.SSS WIL.DCA.RDM.ASK is the source of the data allowed to use the VPN link.
DDD.DDD.DDD.DDD WIL.DCA.RDM.ASK is the destination of the data that need to pass though the VPN link.
5. Define the transformations set that will be used for this VPN connection,
Router(config)#crypto ipsec transform-set SETNAME BBBB CCCCC
where,
SETNAME is the name of the transformations set. You can choose any name you like.
BBBB and CCCCC is the transformation set. I recommend the use of “esp-3des esp-md5-hmac”. You can also use “esp-3des esp-sha-hmac”. Any one of these two will do the job.
6. After defining all the previous things, we need to create a cypto-map that associates the access-list to the other site and the transform set.
Router(config)#crypto map MAPNAME PRIORITY ipsec-isakmp
Router(config-crypto-map)#set peer XXX.XXX.XXX.XXX
Router(config-crypto-map)#set transform-set SETNAME
Router(config-crypto-map)#match address AAA
where,
MAPNAME is a name of your choice to the crypto-map
PRIORITY is the priority of this map over other maps to the same destination. If this is your only crypto-map give it any number, for example 10.
SETNAME is the name of the transformations set that we configured in step 5
AAA is the number of the access-list that we created to define the traffic in step 4
7. The last step is to bind the crypto-map to the interface that connects the router to the other end.
Router(config-if)#crypto map MAPNAME
where MAPNAME is the name of the crypto-map that we defined in step 6.
Now, repeat these steps on the other end, and remember to use the same key along with the same authentication and transform set.
Please Advise,
Junaid
Junaid, Hi,it's me again!!! How have you been?
"VPN Client connects and can use server resources successfully but its own (vpn client's) Internet service stops"
Time to use "Split-tunnelling" for remote access vpn clients.
access-list 111 permit ip 192.168.1.0 0.0.0.255 192.168.55.0 0.0.0.255
access-list 111 permit ip 192.168.74.0 0.0.0.255 192.168.55.0 0.0.0.255
crypto isakmp client configuration group vpnclient
acl 111
Edit: Yes, There is an implicit deny there. However I always configure ACLs to deny/permit the exact traffic for VPN. One thing is to correctly see the hits of traffic flows when using a "show access-list XXX" command. Am I right? (grin)
HTH, What about the rating system? J/K
Toshi
16 Replies 16
Junaid,
Please post configuration regarding NAT and ACLs for VPN interesting traffic,AAA.
Keep in mind you do NAT before cryto functions. So you need to deny interesting traffic in ACLs for NAT(if used).
Let's check out this link: http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080133ddd.shtml
I'm waiting for your reply. (grin)
Toshi
Dear Toshi,
In the above example, Router-A is configured to translate the inside local address 171.68.200.48 to 172.16.47.150, as shown in the configuration below.
The above mentioned IPs are missing in the diagram,,
Please advise
Please see my configuration,, in this router,, remote client vpn and a site to site vpn will run at the same time,,
MTL-2811#sh run
Building configuration...
Current configuration : 6257 bytes
version 12.4
hostname MTL-2811
boot-start-marker
boot-end-marker
enable secret 5 $1xxxxxxxxxxxxxxxxxxxxxxxk0
aaa new-model
aaa authentication login userauthen local
aaa authorization network groupauthor local
aaa session-id common
resource policy
memory-size iomem 10
ip cef
ip domain name millat.com.pk
ip name-server 10.16.6.11
voice-card 0
no dspfarm
username Junaid privilege 15 secret 5 $1xxxxxxxxxxxxxxxxxxxxx/
crypto isakmp policy 3
encr 3des
group 2
crypto isakmp policy 10
hash md5
crypto isakmp key cisco123 address 55.55.233.210 no-xauth
key cisco123
dns 192.168.1.17
wins 192.168.1.17
domain millat.com.pk
pool ippool
crypto ipsec transform-set myset esp-3des esp-md5-hmac
crypto dynamic-map dynmap 10
set transform-set myset
crypto map clientmap client authentication list userauthen
crypto map clientmap isakmp authorization list groupauthor
crypto map clientmap client configuration address respond
crypto map clientmap 1 ipsec-isakmp
set peer 55.55.233.210
match address 100
crypto map clientmap 10 ipsec-isakmp dynamic dynmap
interface FastEthernet0/0
ip address 192.168.74.1 255.255.255.0
ip access-group Internet in
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
ip address 56.56.232.21 255.255.255.248
ip nat outside
duplex auto
speed auto
ip local pool ippool 14.1.1.100 14.1.1.200
ip route 0.0.0.0 0.0.0.0 55.56.232.17
ip route 192.168.1.0 255.255.255.0 192.168.74.2
ip route 192.168.2.0 255.255.255.0 192.168.74.2
ip route 192.168.3.0 255.255.255.0
ip route 192.168.11.0 255.255.255.0 192.168.74.2
ip http server
no ip http secure-server
ip nat inside source static tcp 192.168.1.4 22 interface FastEthernet0/1 22
ip nat inside source static tcp 192.168.74.1 23 interface FastEthernet0/1 23
ip nat inside source static tcp 192.168.1.16 80 interface FastEthernet0/1 80
ip nat inside source static tcp 192.168.1.16 25 interface FastEthernet0/1 25
ip nat inside source static tcp 192.168.1.16 110 interface FastEthernet0/1 110
ip nat inside source static tcp 192.168.1.15 3389 interface FastEthernet0/1 3389
ip nat inside source list 160 interface FastEthernet0/1 overload
ip access-list extended Internet
permit ip host 10.16.6.11 any
permit ip host 10.16.7.12 any
permit tcp any any eq ftp
permit ip host 192.168.10.8 any
permit tcp any any eq smtp
permit tcp any any eq pop3
permit ip host 192.168.2.81 any
permit ip host 192.168.10.7 any
permit ip host 192.168.11.11 any
permit ip host 192.168.4.2 any
permit ip host 192.168.4.81 any
permit ip 192.168.20.0 0.0.0.255 any
permit ip host 192.168.5.8 any
permit ip host 192.168.10.99 any
permit ip host 192.168.9.221 any
permit ip host 192.168.10.215 any
permit ip host 192.168.10.221 any
permit ip 192.168.74.0 0.0.0.255 any
permit ip host 192.168.6.19 any
permit ip host 192.168.1.4 any
permit ip host 192.168.10.208 any
permit ip 192.168.1.0 0.0.0.255 any
access-list 100 permit ip 192.168.74.0 0.0.0.255 192.168.21.0 0.0.0.255
access-list 160 permit ip any any
access-list 160 permit tcp any any
snmp-server community public RO
snmp-server community foobar RO
snmp-server enable traps frame-relay multilink bundle-mismatch
snmp-server enable traps cpu threshold
snmp-server enable traps ipsec tunnel start
snmp-server enable traps ipsec tunnel stop
control-plane
dial-peer cor custom
line con 0
password xxxxxxx
line aux 0
line vty 0 4
password xxxxxxxx
scheduler allocate 20000 1000
end
MTL-2811#
In the above configuration, my internet is running on the internal network,,
Remote User connects via cisco VPN client but unable to get access to my servers in the 192.168.1.0 subnet,,
As well, remote user's Internet service stops,,,,
I would like to solve this issue first,, then I will concentrate to the site-to-site vpn,,,
PLEASE ADVISE
Junaid,
Thanks for useful information. I will give you an example.
- Network's behind RouterA is 192.168.74.0/24
- Network's behind RouterB is 192.168.21/0/24
- They are using F0/1 for WAN interface.
====RouterA=====
ip nat inside source list DENY_LANA_GO_NAT interface F0/1 overload
ip access-list extended DENY_LANA_GO_NAT
deny ip 192.168.74.0 0.0.0.255 192.168.21.0.0 0.0.3.255
ip access-list extended LANA_TO_LANB
permit ip 192.168.74.0 0.0.0.255 192.168.21.0.0 0.0.3.255
Router(config)#crypto map clientmap PRIORITY ipsec-isakmp
Router(config-crypto-map)#match address LANA_TO_LANB
Hopes this link can help you some:http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a00809bd825.shtml
Please let me know how things work out.
HTH,
Toshi
Dear,
Please look into my current configuration now,,,
sh run
Current configuration : 6545 bytes
version 12.4
hostname MTL-2811
boot-start-marker
boot-end-marker
enable secret 5 $1xxxxxxxxxxxxxxxxxxxxxk0
aaa new-model
resource policy
ip cef
voice-card 0
no dspfarm
username Junaid privilege 15 secret 5 $1$ddSB$x5HZhS9Xai9Z6dzvpavLx/
encr 3des
group 2
hash md5
key cisco123
dns 192.168.1.17
wins 192.168.1.17
pool ippool
set peer 55.56.233.210
match address lana_to_lanb
ip nat inside
duplex auto
speed auto
ip address 55.55.232.21 255.255.255.248
ip nat outside
duplex auto
speed auto
ip route 0.0.0.0 0.0.0.0 58.27.232.17
Other routes are added in actual 192.168.3.0 - 11.0, i removed it because of forum restriction
ip http server
ip nat inside source list deny_lana_go_nat interface FastEthernet0/1 overload
permit ip 192.168.11.0 0.0.0.255 any
permit ip host 192.168.2.17 any
ip access-list extended deny_lana_go_nat
deny ip 192.168.74.0 0.0.0.255 192.168.20.0 0.0.3.255
ip access-list extended lana_to_lanb
permit ip 192.168.74.0 0.0.0.255 192.168.20.0 0.0.3.255
control-plane
In this scenario,
- VPN connects, I can ping my servers in 192.168.1.0 network
- unable to remote access my servers let suppose 192.168.1.15
- Local Network (192.168.2.0 - 192.168.11.0) Internet service stops
If I permit 192.168.2.0 - 192.168.11.0 in the extended acl (deny_lana_go_nat), Internet service on internal network Runs but VPN is unable to get access...
My other site (site b) is off right now...
PLEASE ADVISE
Junaid,
Well,Please provide me with the exact traffic going from where to where. Okay let's assume things.
1. Interesting traffic for Site-to-Site VPN is as follows:
SiteA
192.168.74.0 to 192.168.20.0/22
192.168.1.0 to 192.168.20.0/22
SiteB
192.168.20.0/22 to 192.168.74.0/24
192.168.20.0/22 to 192.168.1.0/24
2. Remote access VPN traffic is as follows:
14.1.1.0/24 to 192.168.1.0/24
14.1.1.0/24 to 192.168.74.0/24
Note: Don't use 14.x.x.x again. RFC1918
3. Internet traffic is as follows:
192.168.1.0/24 - 192.168.11.0/24 ,192.168.74.0/24
=======RouterA========
permit ip 192.168.1.0 0.0.0.255 192.168.20.0 0.0.3.255
ip access-list extended DENY_VPN_GO_NAT
deny ip 192.168.74.0 0.0.0.255 14.1.1.0 0.0.0.255
deny ip 192.168.1.0 0.0.0.255 192.168.20.0 0.0.3.255
deny ip 192.168.1.0 0.0.0.255 14.1.1.0 0.0.0.255
permit ip 192.168.0.0 0.0.255.255 any
ip nat inside source list DENY_VPN_GO_NAT interface F0/1 overload
Let's take a deep breath!!!
=======RouterB========
Just for Site-to-Site VPN.
ip access-list extended LANB_TO_LANA
permit ip 192.168.20.0 0.0.3.255 192.168.74.0 0.0.0.255
permit ip 192.168.20.0 0.0.3.255 192.168.1.0 0.0.0.255
crypto map XXXXXX ipsec-isakmp
match address LANB_TO_LANA
Hopes I help you some.(grin)
Toshi
Toshi you are great!!!!
Please see my current configuration, in this scenario, VPN Client connects and can use server resources successfully but its own (vpn client's) Internet service stops,,, I still not attached my site-B, because I will have to go there for configuration,, will tell you about that very soon,
PLEASE ADVISE..
version 12.4
hostname MTL-2811
boot-start-marker
boot-end-marker
enable secret 5 $xxxxxxxxxxxxx0u.
aaa new-model
resource policy
ip cef
voice-card 0
no dspfarm
username Junaid privilege 15 secret 5 $1xxxxxxxxxxxxxxxxxxxDf.
encr 3des
group 2
hash md5
crypto isakmp key cisco123 address 55.56.233.210 no-xauth
key cisco123
dns 192.168.1.17
wins 192.168.1.17
pool ippool
ip nat inside
duplex auto
speed auto
ip address 55.55.232.20 255.255.255.248
ip nat outside
duplex auto
speed auto
ip local pool ippool 192.168.55.100 192.168.55.200
ip route 0.0.0.0 0.0.0.0 55.55.232.17
----- other routes are added, from 3-11
ip http server
ip nat inside source list deny_vpn_go_nat interface FastEthernet0/1 overload
ip access-list extended deny_vpn_go_nat
deny ip 192.168.74.0 0.0.0.255 192.168.55.0 0.0.0.255
deny ip 192.168.1.0 0.0.0.255 192.168.55.0 0.0.0.255
control-plane
line con 0
password Pajero
line aux 0
line vty 0 4
password Pajero2009
MTL-2811#
To save yourself a great deal of headache replace these lines in your deny_vpn_go_nat access list:
Replace these...
With these...
deny ip 10.0.0.0 0.255.255.255 10.0.0.0 0.255.255.255
deny ip 10.0.0.0 0.255.255.255 172.16.0.0 0.15.255.255
deny ip 10.0.0.0 0.255.255.255 192.168.0.0 0.0.255.255
deny ip 172.16.0.0 0.15.255.255 10.0.0.0 0.255.255.255
deny ip 172.16.0.0 0.15.255.255 172.16.0.0 0.15.255.255
deny ip 172.16.0.0 0.15.255.255 192.168.0.0 0.0.255.255
deny ip 192.168.0.0 0.0.255.255 192.168.0.0 0.0.255.255
deny ip 192.168.0.0 0.0.255.255 10.0.0.0 0.255.255.255
deny ip 192.168.0.0 0.0.255.255 172.16.0.0 0.15.255.255
You can do the access list on a subnet by subnet basis, however I've found just adding all of the private subnets is much easier. Then you won't go crazy trying to find NAT problems. There is really no need to NAT any of the private addresses.
Cheers,
Sam
Do I need to add a permit statment like its available in my previous config,,
because, there is an implicit deny at the end of the ACL,, so every traffic will be blocked....
Am I right???
acl 111
Toshi
Hello Toshi,
you did a very good job in this thread
Best Regards
Giuseppe
Giuseppe,
Many Thanks. As far as I know is that you have been helping people(a lot!) here. 5P! as always
Best Regards,
Toshi
Toshi,
You really done a good job, you are great,,,, THANKS..
My one big problem has resolved now, i.e.,, (Remote Client VPN with remote user's internet service),,
Now, I have to connect my site b via vpn,, I will send you site b's config very soon,
Absolutely, you have a right to get (excellent rating) and you will get it very soon :-) as soon my site b will start working,,,
BEST REGARDS,
JUNAID
