Site to Site VPN
morialpesh008
   I have create site to site VPN tunnel and here it the configuration of both router, but when i verify tunnel status using command show crypto session it's show status down, even everything looks ok and both router has reachability to each other, i do not understand why it showing down.
EIGRP configure for routing networks,
R1 configuration
crypto isakmp policy 1
encr aes
authentication pre-share
crypto isakmp key Cisco address 12.0.0.2
crypto ipsec transform-set Test esp-aes 192
crypto map Crypto_map 1 ipsec-isakmp
set peer 12.0.0.2
set transform-set Test
match address 100
access-list 100 permit ip 10.0.0.0 0.0.0.255 192.168.0.0 0.0.0.255
R3 configuration
encr aes
crypto isakmp key Cisco address 11.0.0.1
set peer 10.0.0.1
match address 100
access-list 100 permit ip 192.168.0.0 0.0.0.255 10.0.0.0 0.0.0.255
Alpesh
13 Replies 13
"set peer 11.0.0.1"
Rikshit
Hi rikshit,
   I have changed peer address bit still its showing down.
Alpesh
ip route 0.0.0.0 0.0.0.0 11.0.0.2
ip route 0.0.0.0 0.0.0.0 12.0.0.1
Riksht
post the full configs of R1 and R3...
Hi Georg,
here is full config of both router
R1#show running-config
Building configuration...
Current configuration : 1751 bytes
! Last configuration change at 09:56:37 UTC Tue Feb 21 2017
upgrade fpd auto
version 15.1
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
no ip icmp rate-limit unreachable
ip cef
no ip domain lookup
no ipv6 cef
redundancy
ip tcp synwait-time 5
encr aes
crypto ipsec transform-set IPSEC esp-aes esp-sha-hmac
crypto map CRYPTO 1 ipsec-isakmp
set peer 12.0.0.2
set transform-set IPSEC
match address 100
interface Loopback0
ip address 10.0.0.1 255.255.255.0
interface FastEthernet0/0
no ip address
shutdown
duplex half
interface Serial1/0
ip address 11.0.0.1 255.255.255.252
serial restart-delay 0
crypto map CRYPTO
interface Serial1/1
no ip address
shutdown
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
router eigrp 1
network 11.0.0.0 0.0.0.3
ip forward-protocol nd
no ip http server
no ip http secure-server
logging esm config
no cdp log mismatch duplex
control-plane
mgcp profile default
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
transport input all
end
R3#show running-config
Current configuration : 1754 bytes
! Last configuration change at 09:55:30 UTC Tue Feb 21 2017
upgrade fpd auto
version 15.1
hostname R3
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
ip cef
no ip domain lookup
no ipv6 cef
redundancy
encr aes
set peer 11.0.0.1
match address 100
interface Loopback0
ip address 192.168.0.1 255.255.255.0
no ip address
shutdown
duplex half
interface Serial1/0
ip address 12.0.0.2 255.255.255.252
crypto map CRYPTO
interface Serial1/1
no ip address
shutdown
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
router eigrp 1
network 12.0.0.0 0.0.0.3
no ip http server
logging esm config
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
transport input all
end
R3#
the config you posted is working, to test, try to ping with the loopback being the source:
R3#ping 10.0.0.1 source loopback 0
Sending 5, 100-byte ICMP Echos to 10.0.0.1, timeout is 2 seconds:
Packet sent with a source address of 192.168.0.1
Success rate is 80 percent (4/5), round-trip min/avg/max = 20/21/24 ms
R3#sh crypto session
Crypto session current status
Interface: Serial1/0
Session status: UP-ACTIVE
Peer: 11.0.0.1 port 500
IKEv1 SA: local 12.0.0.2/500 remote 11.0.0.1/500 Active
IPSEC FLOW: permit ip 192.168.0.0/255.255.255.0 10.0.0.0/255.255.255.0
Active SAs: 2, origin: crypto map
Dear Georg,
      Still i am not pinging to my remote site and crypto session is down.
here is the CLI snap of both router.
i am using Cisco IOS Software, 7200 Software (C7200-ADVENTERPRISEK9-M), Version 15.1(4)M, RELEASE SOFTWARE (fc1)
Alpesh
Helllo Alpesh,
when you:
and then issue the command 'show crypto session' it shows as down ? You need to have IPSec traffic, which in your case is traffic from 192.168.0.0 to 10.0.0.0.
Hi georg,
  yes when i issue command ping 10.0.0.1 sou loo0 i don't received any reply form remote and also crypto session status show down(I did as u said).
Alpesh
Hello Alpesh,
can you post the config of R2, the router in between R1 and R3 ?
Hi Georg,
     Here is R2 configuration.
R2#show running-config
Current configuration : 1327 bytes
upgrade fpd auto
version 15.1
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
ip cef
no ip domain lookup
no ipv6 cef
redundancy
no ip address
shutdown
duplex half
interface Serial1/0
ip address 11.0.0.2 255.255.255.252
interface Serial1/1
ip address 12.0.0.1 255.255.255.252
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
router eigrp 1
network 11.0.0.0 0.0.0.255
no ip http server
logging esm config
control-plane
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
transport input all
end
R2#
below is my working configuration. GNS can be buggy, which IOS image are you using ? I am using C7200-ADVIPSERVICESK9-M), Version 15.2(4)S5.
hostname R1
encr aes
set peer 12.0.0.2
match address 100
interface Loopback0
interface Serial1/0
crypto map CRYPTO
router eigrp 1
hostname R2
interface Serial1/0
interface Serial1/1
router eigrp 1
hostname R3
encr aes
set peer 11.0.0.1
match address 100
interface Loopback0
interface Serial1/0
crypto map CRYPTO
router eigrp 1
Hi Georg,
      Yes it possible that some bug BTW I will check using different version of IOS.
thanks for your effort and support.
Alpesh.
