Site2Site VPN hub and spoke with NAT
mattiee
Hello Everyone,
I would like to ask about help with configuration hub and spoke topology between three routers.
I have three LAN networks:
- HUB LAN network 172.28.33.0/24
- SPOKE1 LAN network 172.28.11.0/24
- SPOKE2 LAN network 172.28.22.0/24
There are two IPSec VPN tunnels:
HUB - SPOKE1 : basic tunnel without NAT between networks
HUB - SPOKE2 : tunnel with source NAT from HUB site
On HUB we have also Internet connection with NAT overload for local LAN users.
Topology diagram:
I have a problem with traffic between SPOKE1 and SPOKE2 over existing tunnels via HUB.
Traffic from SPOKE1 enters HUB and leave the HUB on the same interface but I can't see any NAT translations on the HUB. Tunnels between LAN HUB and SPOKE1 and SPOKE2 are working correctly.
Please advice what's missing / wrong in below config.
HUB:
hostname HUB
crypto isakmp policy 10
 encr aes 256
 authentication pre-share
 group 5
 lifetime 28800
crypto isakmp key 123 address 192.168.11.2
crypto isakmp key 123 address 192.168.13.2
crypto ipsec transform-set no1-set ah-sha-hmac esp-aes 256
crypto map no1-map 10 ipsec-isakmp
 set peer 192.168.11.2
 set pfs group5
 set security-association lifetime seconds 28800
 set transform-set no1-set
 match address vpn-traffic-spoke1
crypto map no1-map 20 ipsec-isakmp
 set peer 192.168.13.2
 set pfs group5
 match address vpn2-traffic-spoke2
interface FastEthernet0/1
 ip address 192.168.12.1 255.255.255.0
 ip nat outside
 duplex auto
 speed auto
 crypto map no1-map
interface Ethernet1/0
 ip address 172.28.33.1 255.255.255.0
 ip nat inside
 duplex auto
 speed auto
ip nat pool peer2-pool 192.168.119.25 192.168.119.30 netmask 255.255.255.248
ip nat inside source list INTERNET-NAT interface FastEthernet0/1 overload
ip nat inside source list VPN-NAT-SPOKE2 pool peer2-pool overload
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.12.2
ip access-list extended vpn-traffic-spoke1
 permit ip any 172.28.11.0 0.0.0.255
ip access-list extended INTERNET-NAT
 deny ip 172.28.33.0 0.0.0.255 172.28.22.0 0.0.0.255
 deny ip 172.28.11.0 0.0.0.255 172.28.22.0 0.0.0.255
 permit ip 172.28.33.0 0.0.0.255 any
ip access-list extended vpn2-traffic-spoke2
 permit ip 192.168.119.24 0.0.0.7 172.28.22.0 0.0.0.255
ip access-list extended VPN-NAT-SPOKE2
 permit ip 172.28.33.0 0.0.0.255 172.28.22.0 0.0.0.255
 permit ip 172.28.11.0 0.0.0.255 172.28.22.0 0.0.0.255
end
SPOKE1:
hostname SPOKE1
 encr aes 256
 group 5
 lifetime 28800
crypto isakmp key 123 address 192.168.12.1
 set peer 192.168.12.1
 set pfs group5
interface FastEthernet0/0
 ip address 192.168.11.2 255.255.255.0
 duplex auto
 speed auto
 crypto map no1-map
 ip address 172.28.11.1 255.255.255.0
 duplex auto
 speed auto
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.11.1
ip flow-export version 9
 permit ip 172.28.11.0 0.0.0.255 any
end
SPOKE2:
hostname SPOKE2
 encr aes 256
 group 5
 lifetime 28800
 set pfs group5
 ip address 192.168.13.2 255.255.255.0
 duplex auto
 speed auto
 crypto map no1-map
 ip address 172.28.22.1 255.255.255.0
 duplex auto
 speed auto
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.13.1
 permit ip 172.28.22.0 0.0.0.255 192.168.119.24 0.0.0.7
ahabcaptain
Haven't tested your config but noticed you have typo in second ip nat pointing to VPN-NAT but only acl to match is named VPN-NAT-SPOKE2.
CCIE # 27552 (R&S)
Hi ahabcapitan,
Thank you for your answer. I missed this typo in the post where I was correcting ACL names for better understanding. In the lab I didn't do this mistake. I suppose that problem refers to NAT interface configuration.
Traffic from SPOKE1 to SPOKE2 comes in and out on the same HUB f0/1 interface. Interface f0/1 on the HUB is configured as ip nat outside, so traffic is not passing from ip nat inside interface to ip nat outside and NAT is not applied.
I have some solutions:
1. Perform NAT on a stick via loopback interface on HUB. Not tested yet.
2. Perform source NAT on SPOKE1 with expected source IP. Tested and it's working.
3. Change IPSec tunnel config to use VTI. On HUB set VTI pointing to SPOKE1 tunnel as ip nat inside. Not tested yet.
Regards.
when I change, on Spoke2, the access list:
to
permit ip 172.28.22.0 0.0.0.255 any
and on the HUB:
to
permit ip any 172.28.22.0 0.0.0.255
there is communication between SPOKE1 and SPOKE2. What are you trying to accomplish with the NAT pool ? None of the addresses in the pool seem to be configured anywhere...
