Size limit for PDUs
vpalania
Hi all,
Can anyone summarize the size limit(both max and min) for the following PDUs:
1.Ethernet Frame
2.IP
3.TCP
4.UDP
Kindly give for both headers and data.
Vijay
arvindchari
Level 3
Level 3
The maximum frame size for most ethernet techonologies is 1518 bytes.This varies between 1518 bytes to 1536 bytes as a result of various encapsulations used such as ISL / DOT1Q / other layer 2 encapsulation technologies. Also called the MTU
(Maximum transmission Unit) this value may be definied on most cisco switches on a per vlan basis and go right upto 9000 bytes (search for jumbo frames).
The IPv4 packet size is 32 bits and a great resource for learning about the structure of the same is
http://www.freesoft.org/CIE/Course/Section3/7.htm
For more details on TCP and UDP packet structures visit
http://mike.passwall.com/networking/tcppacket.html
and
http://mike.passwall.com/networking/udppacket.html
respectively
Arvind
Just to add to Arvind's post,
IP: the max header size is contrained by the IHL field of the IP header, which limits the header to 15 4-byte words, or 60 bytes. The total maximum header size is 65535 bytes, including the header.
TCP: Since TCP is carried in IP, the max size of a TCP segment is 65535 - 20 bytes of the TCP header = 65515 bytes. The same applies to UDP.
Hope that helps - pls rate the post if it does.
Paresh
