SLA values extraction using EEM tcl
Siddharth Tyagi
I am trying to extract the numerical value from the followng using Embedded event manager(TCL Scripting)
i also have SLA probes running between 2 connected routers
sho ip sla statistics | sec SD Jitter
So i write the the following
conf ter
event manager applet STAT
event none  sync yes
action 1 cli command "enable"
action 2  cli command "sho ip sla stat | sec SD Jitter"
action 3 regexp  " [0-9]+ " $_cli_result result
action 4 puts "$result"
However it produces result
*Mar 27 16:42:08.806: %HA_EM-3-FMPD_UNKNOWN_ENV: fh_parse_var: could not find environment variable: result
*Mar 27 16:42:08.806: %HA_EM-3-FMPD_ERROR: Error executing applet STAT statement 4
pls clarify
Dragan Ilic
Level 4
Level 4
Could you try with this combination:
action 3 regexp  "[0-9]+" "$_cli_result" result
action 4 puts $result
HTH,
Dragan
HTH,
Dragan
Dragan Ilic
Level 4
Level 4
HTH,
Dragan
HTH,
Dragan
