11-14-2005 04:39 PM - edited 03-03-2019 10:58 AM
Hi, We have a 10mg Long Haul Ethernet connetion between two sites. We have set up seperate Vlans and sub interfaces with the relevant configurations with RIP routing. Connectivity is fine except that FTP file transfer is really slow. When we remove the Router config and configure a Linux box to do the routing for us it works perfectly.The Router port is connected to an HP switch and is showing no errors at all. Any ideas?
11-15-2005 12:48 AM
Hello Steve,
do you see any collisions on the ports connecting the Cisco router and the HP switch ? If so, you might want to try and set the speed and duplex to 100/full, if possible.
Also, do you have CEF ('ip cef' globally) enabled on the Cisco router ?
Can you post the configuration of your Cisco router ?
GP
11-15-2005 05:49 AM
Thanks for your response.
There are no collisions and IP CEF is enabled.
11-16-2005 06:52 AM
GP,
Removing IP cef and then adding it seemed to fix this problem.
Steve
11-16-2005 07:55 AM
Hello Steve,
odd, sounds like a bug. Which IOS version are you running ?
Luckily it works now...
GP
