snmp add OIDs
Hello! I have a cisco-4948-10ge (12.2.54.sg1), and i want to monitor condition of optic transceivers (Rx/Tx power) by snmp. I found this oids:
tools.cisco.com/Support/SNMP/do/BrowseMIB.do?local=en&step=2&mibName=CISCO-OPTICAL-MONITOR-MIB
When i try to snmpwalk, i get this SNMPv2-SMI::enterprises.9.9.264 = No Such Object available on this agent at this OID. As I understand, these oids are supported by ONS 15xxx platforms.
Is there any way to get a possibility of using this oids on my cisco switch?
SNMPv2-SMI::enterprises.9.9.264 = No Such Object available on this agent at this OIDIs
Anyone?
BRIAN SEKLECKI
What you are looking for is located in ENTITY-SENSOR-MIB::entSensorValueTable
Just make sure you turn on DOM monitoring with:
service unsupported-transceiver
transceiver type all
 monitoring
$ snmptable -Cf "," -M +/home/sekleckib/MIBS -v2c -c COMMUNITY-STRING [SwitchLoopback] CISCO-ENTITY-SENSOR-MIB::entSensorValueTable
SNMP table: CISCO-ENTITY-SENSOR-MIB::entSensorValueTable
entSensorType,entSensorScale,entSensorPrecision,entSensorValue,entSensorStatus,entSensorValueTimeStamp,entSensorValueUpdateRate,entSensorMeasuredEntity
celsius,units,1,397,ok,25:19:46:12.30,600 seconds,9125992
voltsDC,units,1,32,ok,25:19:46:12.30,600 seconds,9125992
amperes,milli,1,159,ok,25:19:46:12.30,600 seconds,9125992
dBm,units,1,-59,ok,25:19:46:12.30,600 seconds,9125992
dBm,units,1,-37,ok,25:19:46:12.30,600 seconds,9125992
celsius,units,1,400,ok,25:19:46:13.42,600 seconds,9125992
voltsDC,units,1,32,ok,25:19:46:13.42,600 seconds,9125992
amperes,milli,1,146,ok,25:19:46:13.42,600 seconds,9125992
dBm,units,1,-60,ok,25:19:46:13.42,600 seconds,9125992
dBm,units,1,-108,ok,25:19:46:13.42,600 seconds,9125992
BRIAN SEKLECKI
Also you should rename your Thread's subject to disambiguate it:
"SFP DOM Optical Light Level monitoring on Catalyst 4948 via SNMP MIB"
