SNMP Monitoring of Router
Brian Green
Help!  I have a 2921 router that I am trying to monitor using SNMP polling - I can ping it, SSH to it, get to it via http, but not SNMP.  I know I am using the correct community string - but nothing I try seems to work.  Using the same command to a different 2921 works fine (I am testin with a simple snmpwalk statement).
The interface used for Mangement is inside a VRF - I thought the OS was VRF-aware, so polling should be allowed, but it seems to fail.  I am running 15.3(2) on the router.
Thanks for any help!
Brian
12 Replies 12
Traian Bratescu
You have to specify the vrf for SNMP to work.
snmp-server host {hostname | ip-address} [vrf vrf-name] [traps | informs] [version {1 | 2c | 3 [auth | noauth | priv]}] community-string
Traian
Unfortunately that doesn't want to work.
One thing I didn't express is the Management IP is also in a Vlan, not just a VRF.  And I don't have console access to the device, so I can't move it out (without losing my session).
Help! I'm stumped here!
Brian
Any ACLs between? Routing ok? Can you do a debug snmp packets and see if there is any packet reaching you? How does your setup looks like?
Can you ssh/http from the SNMP server - that way routing would be fine - would still need to check any ACL for UDP 161/162?
Traian
I made a simple test:
fa0/0 - vrf mgmt; directly attached to the server from which I am polling...
interface FastEthernet0/0
 ip vrf forwarding mgmt
 ip address 172.16.200.200 255.255.255.0
R1#sh run | incl snmp
snmp-server community public RO
And SNMP poling is working...
R1#debug snmp packets
SNMP packet debugging is on
*Jul 28 10:00:27.843: SNMP: Packet received via UDP from 172.16.200.1 on FastEthernet0/0
*Jul 28 10:00:27.851: SNMP: Get-next request, reqid 2, errstat 0, erridx 0
 internet.6.3 = NULL TYPE/VALUE
*Jul 28 10:00:27.859: SNMP: Response, reqid 2, errstat 0, erridx 0
 snmpMIB.1.6.1.0 = 0
*Jul 28 10:00:27.867: SNMP: Packet sent via UDP to 172.16.200.1
R1#
*Jul 28 10:01:04.407: SNMP: Packet received via UDP from 172.16.200.1 on FastEthernet0/0
*Jul 28 10:01:04.415: SNMP: Get request, reqid 3, errstat 0, erridx 0
 sysUpTime.0 = NULL TYPE/VALUE
*Jul 28 10:01:04.423: SNMP: Response, reqid 3, errstat 0, erridx 0
 sysUpTime.0 = 48328
*Jul 28 10:01:04.431: SNMP: Packet sent via UDP to 172.16.200.1
ACLs - no
Routing OK - yes.
When I do a debug snmp packets on the router I don't see anything.  I think I'll get a test one (I already have a laptop) to see if the Vlan could be an issue.
Hi Brian,
Can you post show ip route x.x.x.x where x.x.x.x is the SNMP management station from the router, also traceroute from snmp mgmt pc to the routers IP.
show run | in snmp will be helpful too.
Cheers
Hitesh
 can we manage a device through SSH and Poll SNMP from the same IP address?
Hello @Tarun cisco ,
Generally speaking yes this is possible. Depending on the device type , Network Operating System type IOS XE, NXOS, IOS XR it may need different commands.
What device would you like to configure and monitor ?
Hope to help
Giuseppe
Do we have any Techzone or any cisco artical for the same
Firewall device need to be set-up
open a new thread and specify what type of firewall is   (FTD firepower or ASA ), the model and the version of operating system running on it. For FTD devices they can be managed locally by FDM GUI or by a central FMC server. Also this info is needed.
Hope to help
Giuseppe
FTD Firewall and manage by FMC with 7.2 version
