Why can't L3 switch build ipv6 routing table via ospf ?
nmmn1359
Multilayer Switch66 can build ipv4 routing table via ospf.
20.0.0.0/24 is subnetted, 1 subnets
C 20.20.20.0 is directly connected, Vlan10
O IA 192.168.30.0/24 [110/2] via 20.20.20.29, 00:38:20, Vlan10
[110/2] via 20.20.20.69, 00:38:20, Vlan10
Why can't it build 1111::/64 table via ospf ?
C 2222::/64 [0/0]
via ::, Vlan10
L 2222::7777/128 [0/0]
via ::, Vlan10
L FF00::/8 [0/0]
via ::, Null0
Switch66 running config
ip cef
ip routing
ipv6 unicast-routing
ipv6 cef
interface GigabitEthernet1/0/1
switchport access vlan 10
interface GigabitEthernet1/0/2
interface Vlan10
ip address 20.20.20.66 255.255.255.0
ipv6 address 2222::7777/64
ipv6 ospf 1 area 0.0.0.0
router ospf 1
router-id 66.66.66.66
log-adjacency-changes
network 20.20.20.0 0.0.0.255 area 0.0.0.0
ipv6 router ospf 1
area 0.0.0.0 range 2222::/64
Switch69 running config
ip cef
ip routing
ipv6 cef
switchport access vlan 30
interface Vlan10
ip address 20.20.20.69 255.255.255.0
ipv6 address 2222::8888/64
interface Vlan30
ip address 192.168.30.69 255.255.255.0
ipv6 address 1111::8888/64
ipv6 ospf 1 area 192.168.30.0
standby version 2
router ospf 1
router-id 69.69.69.69
network 192.168.30.0 0.0.0.255 area 192.168.30.0
ipv6 router ospf 1
area 192.168.30.0 range 1111::/64
Switch29 has the similar running config with Switch69 but with different ip address and Switch73 acts as a layer 2 switch. The topo shows below.
Giuseppe Larosa
Hello @nmmn1359 ,
check on switch66 if the OSPFv3 adjacency with switch69 is built using
show ipv6 ospf neighbors
This is the first step on troubleshooting.
Hope to help
Giuseppe
This command shows nothing. What configurations do I miss ?
Hello @nmmn1359 ,
switch66 : vlan 10: ipv6 address: ipv6 address 2222::7777/64
and
switch69: vlan 10 :  ipv6 address 2222::8888/64
are in the same /64 IPv6 subnet or are they are in two different IPv6 subnets ?
for me they are in two different IPv6 subnets.
read the following document
https://www.cisco.com/c/en/us/support/docs/ip/ip-version-6-ipv6/112100-ospfv3-config-guide.html?dtid=osscdc000283
look at the configuration of ipv6 address both routers have the following:
ipv6 address FD01:ABAB::/64 eui-64
add eui-64 on your configuration of ipv6 addresses.
OSPFv3 can build adjacency on link local addresses FE80 ...
Hope to help
Giuseppe
Harold Ritter
Hi @nmmn1359 ,
I think this is due to a Cisco Packet Tracer limitation. Try applying the IPv6 configuration directly on the physical instead of the vlan interface and the ipv6 ospf adjacency should come up.
Switch69:
no interface Vlan10
no switchport
Do the same on Switch66 and the session should come up.
