SNMP Object navigator- Ios Version
I m getting the error , not supported for the following Show version in Snmp Object Navigator in this link,
http://tools.cisco.com/Support/SNMP/do/MIBSupport.do?local=en&step=3
sh version
Cisco IOS Software, c7600s3223_rp Software (c7600s3223_rp-IPSERVICES-M), Version
12.2(33)SRB1, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Fri 01-Jun-07 07:53 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)SX3, RELEASE SOFTWARE (fc1)
GJ-AHM-BDH-AR01 uptime is 31 weeks, 4 days, 23 hours, 42 minutes
Uptime for this control processor is 31 weeks, 4 days, 23 hours, 51 minutes
Time since switched to active is 31 weeks, 4 days, 23 hours, 44
minutes
System returned to ROM by power-on (SP by power-on)
System image file is "bootdisk:c7600s3223-ipservices-mz.122-33.SRB1.bin"
Last reload type: Normal Reload
cisco CISCO7609 (R7000) processor (revision 1.2) with 458752K/65536K bytes of me
mory.
Processor board ID FOX11330J4M
R7000 CPU at 300Mhz, Implementation 0x27, Rev 3.3, 256KB L2, 1024KB L3 Cache
Last reset from power-on
2 SIP-200 controllers (32 E1)(2 POS).
1 Virtual Ethernet interface
48 FastEthernet interfaces
18 Gigabit Ethernet interfaces
32 Serial interfaces
32 Channelized E1 ports
2 Packet over SONET interfaces
1915K bytes of non-volatile configuration memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Joe Clarke
Try my MIBs In Images tool instead. Send an email to mii@external.cisco.com with "c7600s3223-ipservices-mz.122-33.SRB1.bin" in the body, and you'll get your list. I've updated the MIB Locator feeder tool, but it will take time to propagate the change.
