SNMP Related Services
ehtesham.ahmed1
Can we use the Mgmt port (int GigabitEthernet 0) SNMP without removing the existing Interface.??
Router(config)# snmp-server view myview mib-2 included
Router(config)# snmp-server trap link ietf
Router(config)# snmp-server trap-source GigabitEthernet0/0/0
Hello @ehtesham.ahmed1 ,
>> we need both interface in SNMP… int Gi0/0/0 and int Gig0
I'm afraid this is not supported as the purpose of the command is to use a single source address when sending SNMP packets in order to make easier the device identification on the management servers.
This is why the second instance of the command overwrites the previous one.
Hope to help
Giuseppe
Mark Elsen
 - That should work
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Yes, Its work.
When giving to command in SMNP, it will remove the existing int gi0/0/0.
Only accept one interface in SNMP ..
Hope to help
Giuseppe
