SNMP Trap
jocampo35116
Hi team Netpro -
Is there anybody who encountered this type of error "SNMPTrap Average_Round_Trip_Delay_100%_over_baseline" " ? and if possible provide a reference guide or tips on how to fix it .
thank you.
Calin C.
Level 5
Level 5
Hi!
I remember that once I had this message, but not exactly like this. Anyway, I would advice you to check the connectivity between the machine that is receiving the traps and your Cisco device. If you have connectivity, please check what RTT you have in between.
In the meantime I will try to find the message that I had.
Cheers,
Calin
