SNMP Traps for hardware errors
Ricky S
Level 3
Level 3
Hi folks, was wandering if anyone can lend a quick hand with this one. We have a router that's been registering the following events in its local log:
Sep 30 09:32:27.212 EDT: %ENVMON-3-FAN_FAILED: Fan 1 not rotating
I have configured SNMP traps for link up/down on this router however nothing for a hardware error such as above. What SNMP trap can I enable that will allow my NMS to start receiving notification of all similar issues and events?
6 Replies 6
singhaam007
Level 3
Level 3
Hi Ricky,
you can use this
snmp-server enable traps envmon fan shutdown supply temperature status
thanks
Hi Amrinder, this is what I have
ip access-list standard snmp_hosts
permit 172.18.120.241
deny   any
snmp-server community xxxx RO snmp_hosts
snmp-server community xxxx RW snmp_hosts
snmp-server trap-source GigabitEthernet0/1
snmp-server enable traps envmon fan statuschange
snmp-server host 172.18.120.241 version 2c xxxx envmon
snmp-server manager
I have checked the community strings and they match.
Interface GigabitEthernet0/1 can communicate with 172.18.120.241
However my end stations is still not seeing any traps coming from this router.
hello Ricky,
is there any access list blocking ip address for GigabitEthernet0/1 ?
try Show snmp and see if actually that’s running.
Add this to your snmp config
(this ine enables the router to send Entity MIB notifications in addition
to any traps or informs previously enabled)
snmp-server host 172.18.120.241 public snmp envmon
(replace public with you community string)
see if this make any difference .
thanks
No ACL on Gig0/1
Here is the output from show snmp command
ORL-ISR1#sh snmp
Chassis: *********
178439 SNMP packets input
    0 Bad SNMP version errors
    119414 Unknown community name
    0 Illegal operation for community name supplied
    0 Encoding errors
    100797 Number of requested variables
    0 Number of altered variables
    56138 Get-request PDUs
    1727 Get-next PDUs
    0 Set-request PDUs
    0 Input queue packet drops (Maximum queue size 1000)
59024 SNMP packets output
    0 Too big errors (Maximum packet size 1500)
    25 No such name errors
    0 Bad values errors
    0 General errors
    59024 Response PDUs
    0 Trap PDUs
After I punched in snmp-server enable traps, it enabled a lot of them
Thats when I also captured 2 traps at my NMS but not the ones I'm looking for i.e. Fan.
Please advise
Your show snmp information is not showing if these traps are enabled or not.
Check this example
Network#sh snmp
Chassis: XXXXXX
Contact: XXXXXX
3304795 SNMP packets input
   277 Unknown community name
   2 Illegal operation for community name supplied
   0 Encoding errors
   8032936 Number of requested variables
   3047744 Get-request PDUs
   242322 Get-next PDUs
   0 Set-request PDUs
3586906 SNMP packets output
   1220 No such name errors
   0 Bad values errors
   0 General errors
   3304486 Response PDUs
   282420 Trap PDUs
SNMP global trap: enabled
SNMP logging: enabled
   Logging to XXXXXXXXXXX, 0/10, 141137 sent, 73 dropped.
   Logging to XXXXXXXXXXX, 0/10, 141134 sent, 76 dropped.
SNMP agent enabled.
But other than that everything looks fine .
Please try this command again.
thanks
