High CPU load with IP input on Cisco 881
Greg Maaaag
Good day!
Here is my conf:
no service pad
service password-encryption
hostname IT
boot-start-marker
boot-end-marker
enable secret 5 *
no aaa new-model
memory-size iomem 10
crypto pki trustpoint TP-self-signed-3898150452
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3898150452
revocation-check none
crypto pki certificate chain TP-self-signed-3898150452
certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 33383938 31353034 3532301E 170D3132 30383231 30383239
  34395A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 38393831
  35303435 3230819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100948E 9DB523FC 3358CFED 558C315B 662AEB5B 19A4DC22 3E9682B5 CD8A5554
  619E9404 C043E3B0 78B63FCB 0088B310 FBF9C7BA 796D79B5 2369FF84 9F82B388
  75C986FA B8C3CDE1 0F84FA59 A48C5A45 62648E87 2E777CE8 FBEB7F5E BAE5BABD
  8F0CD6A0 B60BABAC 522E0989 1EE0BFA8 7F533FA5 6D443721 2204830A 6BE4541C
  B5650203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 14723AD8 E7EBA8F3 60BF92D7 817761D4 D47D5A3F BD301D06
  03551D0E 04160414 723AD8E7 EBA8F360 BF92D781 7761D4D4 7D5A3FBD 300D0609
  2A864886 F70D0101 04050003 8181002F FDB5515E 7F1A8B8B BBB7EBD4 4C19F32B
  7D30060A C7436AD3 8B1778E6 3AD65F5D 3C69785A 1748E814 78246D70 211ACC80
  42CC42AE 9D280FED C8C06065 80E22C91 E56D4560 6359AF2E AC497B0D EAF92ECB
  0C06D617 F18E9F5A C3F8E5E3 EDD32E18 8520997D 08673F19 339DBDA8 9282200D
  C409A8D3 6408E667 42BFFE7C 7D56A2
        quit
ip source-route
ip dhcp excluded-address 192.168.10.1 192.168.10.99
ip dhcp excluded-address 192.168.10.201 192.168.10.254
ip dhcp pool pool
import all
network 192.168.10.0 255.255.255.0
default-router 192.168.10.12
dns-server 192.168.10.100 192.168.240.100
ip cef
no ip domain lookup
ip domain name office
ip name-server 8.8.8.8
no ipv6 cef
license udi pid CISCO881W-GN-E-K9 sn FCZ1539C4KL
username admin privilege 15 secret 5 *
username wifiap privilege 15 secret 5 *
ip tcp synwait-time 5
ip ftp source-interface Vlan1
ip ftp username cisco
ip ftp password 7 08305B4B584B56
crypto isakmp policy 10
encr aes
hash md5
authentication pre-share
group 2
lifetime 3600
crypto isakmp policy 20
encr 3des
group 2
lifetime 3600
crypto isakmp key 6 * address 89.*.*.92
crypto isakmp key 6 * address *
crypto ipsec transform-set myset esp-aes esp-md5-hmac
crypto ipsec transform-set sharepoint esp-3des esp-sha-hmac
crypto map vpn 10 ipsec-isakmp
set peer 89.*.*92
set transform-set myset
match address 102
crypto map vpn 30 ipsec-isakmp
set peer *
set transform-set sharepoint
match address 103
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
ip address 89.*.*.226 255.255.255.240
ip flow ingress
ip nat outside
ip virtual-reassembly in
ip route-cache same-interface
ip route-cache policy
duplex auto
speed auto
crypto map vpn
interface wlan-ap0
description Service module interface to manage the embedded AP
ip address 192.168.110.110 255.255.255.0
arp timeout 0
interface Wlan-GigabitEthernet0
description Internal switch interface connecting to the embedded AP
switchport mode trunk
no ip address
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
ip address 192.168.10.12 255.255.255.0
ip nat inside
interface Vlan2
ip address 192.168.25.12 255.255.255.0
ip nat inside
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip nat pool NEW 89.*.*.226 89.*.*.226 prefix-length 24
ip nat pool AD 192.168.10.100 192.168.10.100 netmask 255.255.255.0 type rotary
ip nat inside source list 100 pool NEW overload
ip nat inside source static tcp 192.168.10.4 1723 89.*.*.226 1723 extendable
ip nat inside source static tcp 192.168.10.4 3389 89.*.*.226 3389 extendable
ip nat inside source static tcp 192.168.10.11 8081 89.*.*.226 8081 extendable
ip nat inside destination list 110 pool AD
ip route 0.0.0.0 0.0.0.0 89.*.*.225
ip route 192.168.25.0 255.255.255.0 192.168.10.4
access-list 100 deny   ip 192.168.10.0 0.0.0.255 192.168.2.0 0.0.0.255
access-list 100 deny   ip 192.168.10.0 0.0.0.255 192.168.3.0 0.0.0.255
access-list 100 deny   ip 192.168.10.0 0.0.0.255 192.168.12.0 0.0.0.255
access-list 100 deny   ip 192.168.10.0 0.0.0.255 192.168.15.0 0.0.0.255
access-list 100 deny   ip 192.168.10.0 0.0.0.255 192.168.16.0 0.0.0.255
access-list 100 deny   ip 192.168.10.0 0.0.0.255 192.168.17.0 0.0.0.255
access-list 100 deny   ip 192.168.10.0 0.0.0.255 192.168.18.0 0.0.0.255
access-list 100 deny   ip 192.168.10.0 0.0.0.255 192.168.19.0 0.0.0.255
access-list 100 deny   ip 192.168.10.0 0.0.0.255 192.168.25.0 0.0.0.255
access-list 100 deny   ip 192.168.10.0 0.0.0.255 192.168.181.0 0.0.0.255
access-list 100 deny   ip 192.168.10.0 0.0.0.255 192.168.200.0 0.0.0.255
access-list 100 deny   ip 192.168.10.0 0.0.0.255 192.168.240.0 0.0.0.255
access-list 100 deny   ip 192.168.10.0 0.0.0.255 192.168.250.0 0.0.0.255
access-list 100 deny   ip 192.168.10.0 0.0.0.255 10.0.1.0 0.0.0.255
access-list 100 permit ip 192.168.10.0 0.0.0.255 any
access-list 102 permit ip 192.168.10.0 0.0.0.255 192.168.2.0 0.0.0.255
access-list 102 permit ip 192.168.10.0 0.0.0.255 192.168.3.0 0.0.0.255
access-list 102 permit ip 192.168.10.0 0.0.0.255 192.168.12.0 0.0.0.255
access-list 102 permit ip 192.168.10.0 0.0.0.255 192.168.15.0 0.0.0.255
access-list 102 permit ip 192.168.10.0 0.0.0.255 192.168.16.0 0.0.0.255
access-list 102 permit ip 192.168.10.0 0.0.0.255 192.168.17.0 0.0.0.255
access-list 102 permit ip 192.168.10.0 0.0.0.255 192.168.18.0 0.0.0.255
access-list 102 permit ip 192.168.10.0 0.0.0.255 192.168.19.0 0.0.0.255
access-list 102 permit ip 192.168.10.0 0.0.0.255 192.168.181.0 0.0.0.255
access-list 102 permit ip 192.168.10.0 0.0.0.255 192.168.200.0 0.0.0.255
access-list 102 permit ip 192.168.10.0 0.0.0.255 192.168.240.0 0.0.0.255
access-list 102 permit ip 192.168.10.0 0.0.0.255 192.168.250.0 0.0.0.255
access-list 102 permit ip 192.168.10.0 0.0.0.255 10.0.1.0 0.0.0.255
access-list 103 permit ip 192.168.10.0 0.0.0.255 192.168.40.0 0.0.0.255
access-list 110 permit tcp any any range 3268 3269
access-list 110 permit tcp any any eq 389
access-list 110 permit udp any any eq 389
access-list 110 permit udp any any eq 636
access-list 110 permit tcp any any eq 636
no cdp run
route-map SHAREPOINT permit 20
match ip address 103
set interface FastEthernet4
route-map IPSEC-TRAF permit 10
match ip address 102
line con 0
exec-timeout 30 30
privilege level 15
password 7 060506324F41584B56
logging synchronous
login
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
line vty 0 4
privilege level 15
password 7 072871551A0B2B5241
login local
transport input all
end
show proc cpu sorted 1
CPU utilization for five seconds: 99%/56%; one minute: 99%; five minutes: 99%
PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
106    12469004      635891      19608 39.23% 38.88% 42.83%   0 IP Input
  82      443152       42173      10507  1.11%  1.27%  1.45%   0 COLLECT STAT COU
  80      277664       49943       5559  1.19%  1.09%  1.10%   0 i2c sm_exchange
  79       75788      128397        590  0.47%  0.46%  0.24%   0 SEC BATCH
show interfaces FastEthernet 4
FastEthernet4 is up, line protocol is up
  Hardware is PQII_PRO_UEC, address is 7081.05a0.97be (bia 7081.05a0.97be)
  Internet address is 89.104.102.226/28
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
     reliability 255/255, txload 30/255, rxload 41/255
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, 100BaseTX/FX
  Last input 00:00:00, output 00:00:00, output hang never
  Input queue: 30/75/14250/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 16245000 bits/sec, 1946 packets/sec
  5 minute output rate 12003000 bits/sec, 1907 packets/sec
     29306702 packets input, 1552528471 bytes
     Received 37493 broadcasts (0 IP multicasts)
     867 runts, 0 giants, 4348 throttles
     4746 input errors, 0 CRC, 0 frame, 4585 overrun, 161 ignored
     0 watchdog
     27453647 packets output, 1824988727 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
     12353 unknown protocol drops
     0 lost carrier, 0 no carrier
show interfaces FastEthernet 4 switching
FastEthernet4
          Throttle count       4383
                   Drops         RP      14301         SP          0
             SPD Flushes       Fast          0        SSE          0
             SPD Aggress       Fast          0
            SPD Priority     Inputs       1233      Drops          0
    Protocol  IP
          Switching path    Pkts In   Chars In   Pkts Out  Chars Out
                 Process   16185388 1276887927    9057611  596342143
            Cache misses          0          -          -          -
                    Fast   13439853  699219156   18687667 1399098080
               Auton/SSE          0          0          0          0
    Protocol  ARP
                 Process      23934    1446298         72       4320
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
    Protocol  Other
                 Process      12479    1731848          0          0
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
How can i prevent it?
6 Replies 6
skarthic
Hi Greg,
As per the router performance document, you might be seeing a platform limitation. Best way to confirm this would be to check with TAC.
http://www.cisco.com/web/partners/downloads/765/tools/quickreference/routerperformance.pdf
I do see a lot of process switching happening too which is not the ideal method of packet switching.
56% due to interrupts
43% due to processes out of which 40% is due to "IP Input" which is related to process switching.
Can you check "show ip cef switching statistics feature" to see which feature is causing the packets to get process switched?
The config mostly looks fine.
Karthic
Thank you for your answer!
Can you please tell, if config mostly looks fine, what isn't fine in it?:)
#show ip cef switching statistics feature
IPv4 CEF input features:
       Feature                Drop    Consume       Punt  Punt2Host Gave route
       Virtual Fragment      30573    2482032          0          0          0
       IPSec input clas       3808  233310808          0      13743          0
       NAT Outside               5          0          0  448269286          0
Total                        34386  235792840          0  448283029          0
IPv4 CEF output features:
       Feature                Drop    Consume       Punt  Punt2Host    New i/f
       Post-routing NAT          2          0          0  248475585          0
       IPSec output cla       1995          0          0          0          0
       IPSec: to crypto          0  159380476          0          0          0
Total                         1997  159380476          0  248475585          0
IPv4 CEF post-encap features:
Total                            0          0          0          0          0
IPv4 CEF for us features:
Total                            0          0          0          0          0
IPv4 CEF punt features:
Total                            0          0          0          0          0
IPv4 CEF local features:
Total                            0          0          0          0          0
and
show ip traffic
IP statistics:
  Rcvd:  709394331 total, 7659030 local destination
         0 format errors, 0 checksum errors, 102917 bad hop count
         0 unknown protocol, 3 not a gateway
         0 security failures, 0 bad options, 5189 with options
  Opts:  0 end, 0 nop, 0 basic security, 0 loose source route
         0 timestamp, 0 extended security, 0 record route
         0 stream ID, 0 strict source route, 5189 alert, 0 cipso, 0 ump
         0 other
  Frags: 13625 reassembled, 8 timeouts, 0 couldn't reassemble
         10233 fragmented, 20468 fragments, 29 couldn't fragment
  Bcast: 513555 received, 3876 sent
  Mcast: 0 received, 0 sent
  Sent:  4930701 generated, 1333377882 forwarded
  Drop:  151 encapsulation failed, 0 unresolved, 0 no adjacency
         499 no route, 0 unicast RPF, 0 forced drop
         0 options denied
  Drop:  0 packets with source IP address zero
  Drop:  0 packets with internal loop back IP address
         12237 physical broadcast
  Reinj: 0 in input feature path, 46 in output feature path
ICMP statistics:
  Rcvd: 39 format errors, 0 checksum errors, 0 redirects, 2467 unreachable
        2071 echo, 7 echo reply, 0 mask requests, 0 mask replies, 1 quench
        0 parameter, 0 timestamp, 0 timestamp replies, 0 info request, 0 other
        0 irdp solicitations, 0 irdp advertisements
        16 time exceeded, 0 info replies
  Sent: 0 redirects, 327552 unreachable, 98 echo, 2071 echo reply
        0 mask requests, 0 mask replies, 0 quench, 0 timestamp, 0 timestamp repl        ies
        0 info reply, 47 time exceeded, 0 parameter problem
TCP statistics:
  Rcvd: 6654094 total, 28 checksum errors, 12701 no port
  Sent: 4591011 total
PIMv2 statistics: Sent/Received
  Total: 0/0, 0 checksum errors, 0 format errors
  Registers: 0/0 (0 non-rp, 0 non-sm-group), Register Stops: 0/0,  Hellos: 0/0
  Join/Prunes: 0/0, Asserts: 0/0, grafts: 0/0
  Bootstraps: 0/0, Candidate_RP_Advertisements: 0/0
  Queue drops: 0
  State-Refresh: 0/0
IGMP statistics: Sent/Received
  Total: 0/0, Format errors: 0/0, Checksum errors: 0/0
  Host Queries: 0/0, Host Reports: 0/0, Host Leaves: 0/0
  DVMRP: 0/0, PIM: 0/0
  Queue drops: 0
UDP statistics:
  Rcvd: 996430 total, 0 checksum errors, 979398 no port
  Sent: 9959 total, 0 forwarded broadcasts
OSPF statistics:
  Last clearing of OSPF traffic counters never
  Rcvd: 0 total, 0 checksum errors
        0 hello, 0 database desc, 0 link state req
        0 link state updates, 0 link state acks
  Sent: 0 total
ARP statistics:
  Rcvd: 1778041 requests, 187 replies, 17226 reverse, 0 other
  Sent: 490798 requests, 63567 replies (1025 proxy), 0 reverse
  Drop due to input queue full: 0
I see too many incoming ARP requests and many bad hoop count...
As you see, we've got vpn tunnels with many subnets, can it be connected with it?)
About external brandwith, it's 20mb\s so i guess it isn't limit for 881w )
paolo bevilacqua
I would start with 'no ip reassemly" and summarizing the ACL entries.
Summarazing like 192.168.0.0\16 ?
'no ip reassemly' this command isn't found
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
e.g.
can be
access-list 100 deny   ip 192.168.10.0 0.0.0.255 192.168.16.0 0.0.3.255
Typo. no ip virtual-reassembly.
