SNMP
KaliRathinam
How will check SNMP is working or not in a cisco router without using any management tool.
aijaz802
If you see "no snmp-server" in your cisco router's running configuration this means snmp disabled n not running.....otherwise the snmp is enabled...
Hope this helps, if so, pls rate it.
*aijaz*
