So practising bgp on eve ng, have an issue
kbk989
So i have the following topology-
ISP-RT-1 has a default route pointing to 192.168.20.1
Image being used is - vios-adventerprise9-m.SPA.159-3.M6
Some show commands-
ISP-RT-1#show ip bgp 0.0.0.0
BGP routing table entry for 0.0.0.0/0, version 2
Paths: (1 available, best #1, table default)
Advertised to update-groups:
Refresh Epoch 1
Local
192.168.20.1 from 0.0.0.0 (1.1.1.1)
Origin IGP, metric 0, localpref 100, weight 32768, valid, sourced, local, best
rx pathid: 0, tx pathid: 0x0
Now im trying to aadvertise this to the 3 ibgp peers (1 of them not shown in the pic but its just a direct point to point) and it doesnt work at all-
ISP-RT-1#show running-config | section bgp
router bgp 65312
bgp log-neighbor-changes
network 0.0.0.0
neighbor 65.30.24.1 remote-as 65312
neighbor 65.30.24.5 remote-as 65312
neighbor 65.30.24.9 remote-as 65312
ISP-RT-1#show ip bgp summary
BGP router identifier 1.1.1.1, local AS number 65312
BGP table version is 2, main routing table version 2
1 network entries using 144 bytes of memory
1 path entries using 84 bytes of memory
1/1 BGP path/bestpath attribute entries using 160 bytes of memory
0 BGP route-map cache entries using 0 bytes of memory
0 BGP filter-list cache entries using 0 bytes of memory
BGP using 388 total bytes of memory
BGP activity 1/0 prefixes, 1/0 paths, scan interval 60 secs
Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd
65.30.24.1 4 65312 9 10 2 0 0 00:04:59 0
65.30.24.5 4 65312 9 11 2 0 0 00:04:49 0
65.30.24.9 4 65312 9 11 2 0 0 00:04:37 0
If i look at the routing table on say ISP-RT-2 it doesnt learn the default route, what am i doing wrong?
ISP-RT-2#show ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
a - application route
+ - replicated route, % - next hop override, p - overrides from PfR
Gateway of last resort is not set
2.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 2.2.2.0/24 is directly connected, Loopback0
L 2.2.2.2/32 is directly connected, Loopback0
65.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 65.30.24.0/30 is directly connected, GigabitEthernet0/1
L 65.30.24.1/32 is directly connected, GigabitEthernet0/1
Its the same on the other 2 routers as well and they do not learn the default route, so yeah no idea whats going on.
Ive researched online and everywhere i look they say all i need is a "network 0.0.0.0" statement which i tried as you can see but yeah doesnt work.
Thank You
2 Accepted Solutions
Martin L
from CCIE v5 vol. 2 by Narbik, Vinston, Cisco Press.
Regards, ML
**Have fun labbing!!!***
***Please Rate All Helpful Responses ***
In this video, learn how to advertise default routes in Border Gateway Protocol (BGP) to optimize your network routing. We'll guide you through the steps and best practices for configuring BGP to advertise default routes, ensuring seamless routing and connectivity in large-scale networks. Related
17 Replies 17
You need to use defualt information originate under bgp.
MHM
so yeah i tried that too and it doesnt work, could it have something to do with the image im using? i do have a csr1000v image as well which i can use.
Bgp advertise 0.0.0.0 only if this appear in RIB
Can i see
Show ip route
MHM
yes it does have it-
ISP-RT-1#show ip route
Gateway of last resort is 192.168.20.1 to network 0.0.0.0
S* 0.0.0.0/0 [254/0] via 192.168.20.1
1.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 1.1.1.0/24 is directly connected, Loopback0
L 1.1.1.1/32 is directly connected, Loopback0
65.0.0.0/8 is variably subnetted, 6 subnets, 2 masks
L 65.30.24.2/32 is directly connected, GigabitEthernet0/1
C 65.30.24.4/30 is directly connected, GigabitEthernet0/2
L 65.30.24.6/32 is directly connected, GigabitEthernet0/2
C 65.30.24.8/30 is directly connected, GigabitEthernet0/3
L 65.30.24.10/32 is directly connected, GigabitEthernet0/3
192.168.20.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.20.0/24 is directly connected, GigabitEthernet0/0
L 192.168.20.106/32 is directly connected, GigabitEthernet0/0
192.168.20.1 <<- this IP reachable via other ibgp neighbors
MHM
If this IP not know
Use next-hop self
Abd network 0.0.0.0 under bgp
MHM
ah ok ill try next hop self
M02@rt37
Hello @kbk989
Because the static default is not present in the routing table, the network 0.0.0.0 statement in BGP has no effect...
=> so nothing is advertised to your iBGP peers.
Best regards
i see makes sense
Still not get defualt in ibgp?
MHM
Show ip bgp neighbors x.x.x.x advertise <<- share this in router
Show ip bgp neighbors x.x.x.x receive <<- share this in remote router
Share debug ip bgp update after you clear ip bgp process for both router and remote one
MHM
Martin L
is it working now? Book by W. Odom CCIE v4 RS has a summary table that shows 3 ways to advertised default route under bgp. I recommend his book. (topic replicated into CCIE v5 RS book I think)
Regards, ML
next hop issue how I know that ?
Refresh Epoch 1
Local
solution is next hop self
Screenshot (1020).pngScreenshot (1021).pngScreenshot (1022).pngScreenshot (1023).pngScreenshot (1024).pngScreenshot (1025).png
NOTE:- use debug ip bgp update next time in trouble
NOTE:- clear ip bgp <<- when you add or remove any command of BGP
MHM
other solution
use
neighbour x.x.x.x default-information <<- under R2 (router have static default route)
