SolarWinds Reporting and Configured Bandwidth
Patrick McHenry
Level 4
Level 4
I'm wondering where in the config I should configure the bandwidth that Solarwinds will use to measure the percent usage? For instance: under the interface command, if I configure bandwidth 1000, will SolarWinds  think that the interface is 1000000 mbps and display the interfaces' percent utilization based on that?
Thank you, Pat.
John Blakley
Pat,
With Solarwinds, it does take into account the bandwidth statement because that directly affects the interface BW. You can also, but I wouldn't recommend it, change the bandwidth under the interface in Solarwinds directly under "manage nodes\router\interface". There's a section for Customize Bandwidth. You'll notice that it references the bandwidth that you have configured under the interface. If you don't reference a specific bandwidth, it will use the bw that it finds for that interface using snmp.
HTH,
John
HTH, John *** Please rate all useful posts ***
John Blakley
Pat,
HTH,
John
