Solution for a routing topology with 8x Cisco 2811
I want to make a real lab topology to compare different routing protocols with maximum 4 routing interfaces per router. The problem is that i have 8x Cisco 2811 routers, each has only 2 x routing interfaces + 8 x feSW interfaces.
I tried to resolve this as fallows: use 2 x 2811 router for equivalent of one router with 4 routing interfaces (I connected the two routers between them by SW interfaces) (see attachment)
I configured EIGRP and I can`t ping between any two LANs connected to cisco 2811 routers. (EIGRP updates can`t be propagated between the two LANs connected to 2 different routers)
Is there any solution to resolve this VLANs or something like this) or to make a topology with the purpose of comparing RIP, EIGRP and OSPF on a platform with 8 x Cisco 2811 routers?
Sorry for my poor english!
Sorry, but i can't open packet tracer. Also your diagram doesn't says which router is R4, R5, R6 or R7. But below is what i understood:
SW interfaces will be in VLAN1 by default, as you have not defined any other Vlans.
Sso if you try to make connection via SW interfaces, then you need to define IPs on vlan 1 and make the subnet in eigrp. In real world it will be simmiler to a Routering Interfaces and reffered as SVI.
For example, if you have two router and they are connected via SW interfaces as:
R1-Fa0/1/0 ---- R2-Fa0/1/0
Then on R1
vlan 10
 name L3-SVI-10
Int vlan 10
 ip add 192.168.1.1 255.255.255.0
Interface fa0/1/0
 switchport mode access
 switchport access vlan 10
router eigrp
 network 192.168.1.0
 no auto-summary
end
and on R2
vlan 10
name L3-SVI-10
Int vlan 10
ip add 192.168.1.2 255.255.255.0
Interface fa0/1/0
router eigrp
network 192.168.1.0
 no auto-summary
end
Can you share the configs ?
Basically, the problem i had illustrated in packet tracer in the attachment.
R7
interface FastEthernet0/0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
router eigrp 1
network 192.168.1.0
auto-summary
R4
ip address 192.168.1.2 255.255.255.0
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
interface FastEthernet0/1/0
interface FastEthernet0/1/1
interface FastEthernet0/1/2
shutdown
interface FastEthernet0/1/3
shutdown
interface Vlan1
no ip address
shutdown
router eigrp 1
network 192.168.1.0
network 192.168.2.0
auto-summary
R5
ip address 192.168.2.1 255.255.255.0
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
shutdown
shutdown
interface Vlan1
no ip address
shutdown
router eigrp 1
network 192.168.1.0
network 192.168.2.0
auto-summary
R6
ip address 192.168.2.2 255.255.255.0
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
router eigrp 1
network 192.168.2.0
auto-summary
Then on R1
vlan 10
 name L3-SVI-10
Int vlan 10
Interface fa0/1/0
router eigrp
 network 192.168.1.0
 no auto-summary
end
and on R2
vlan 10
name L3-SVI-10
Int vlan 10
Interface fa0/1/0
router eigrp
network 192.168.1.0
 no auto-summary
end
niketanvaidya
Plz disable auto summary of Eigrp
