SOLVED: Cisco 2921: configuring 3G EHWIC
Hi folks !
I've got Cisco 2921 with IOS image is c2900-universalk9-mz.SPA.151-4.M4.bin.
Also I installed EHWIC-3G-HSPA+7 with a working SIM card (yeah, it's work was verified) according to this document. But the router reports that the SIM is removed:
R1# show cellular 0/0/0 security
Card Holder Verification (CHV1) = Disabled
SIM Status = Removed
SIM User Operation Required = None
Number of CHV1 Retries remaining = 255
I've doublechecked if the SIM was correctly and tried to insert a SIM from different operator but with no effect. The state is still "Removed". There is actually no configuration completed for the controller (see running config in attachment).
There's output of another command:
R1# show cellular 0/0/0 all
Hardware Information
Modem Firmware Version = T1_0_3_2AP R361 CNSZ
Modem Firmware built = 04/15/11
Hardware Version = 1.0
International Mobile Subscriber Identity (IMSI) = 00000
International Mobile Equipment Identity (IMEI) = 1324132412341324
Integrated Circuit Card ID (ICCID) =
Mobile Subscriber International Subscriber
IDentity Number (MSISDN) =
Factory Serial Number (FSN) = CC3211234123407
Modem Status = Online
Current Modem Temperature = 19 deg C, State = Normal
PRI SKU ID = 8994196, SKU Rev. = 1.2
Profile Information
Profile password Encryption level: 7
Profile 1 = INACTIVE*
PDP Type = IPv4
Access Point Name (APN) =
Authentication = None
Username:
Password: 05
 * - Default profile
Data Connection Information
Data Transmitted = 0 bytes, Received = 0 bytes
Profile 1, Packet Session Status = INACTIVE
Inactivity Reason = Normal inactivate state
Profile 2, Packet Session Status = INACTIVE
Profile 3, Packet Session Status = INACTIVE
Profile 4, Packet Session Status = INACTIVE
Profile 5, Packet Session Status = INACTIVE
Profile 6, Packet Session Status = INACTIVE
Profile 7, Packet Session Status = INACTIVE
Profile 8, Packet Session Status = INACTIVE
Profile 9, Packet Session Status = INACTIVE
Profile 10, Packet Session Status = INACTIVE
Profile 11, Packet Session Status = INACTIVE
Profile 12, Packet Session Status = INACTIVE
Profile 13, Packet Session Status = INACTIVE
Profile 14, Packet Session Status = INACTIVE
Profile 15, Packet Session Status = INACTIVE
Profile 16, Packet Session Status = INACTIVE
Network Information
Current Service Status = Emergency Only, Service Error = None
Current Service = Invalid
Packet Service = None
Packet Session Status = Inactive
Current Roaming Status = Home
Network Selection Mode = Automatic
Country = BLR, Network = VELCOM
Mobile Country Code (MCC) = 257
Mobile Network Code (MNC) = 1
Location Area Code (LAC) = 777
Routing Area Code (RAC) = 31
Cell ID = 38843
Primary Scrambling Code = 129
PLMN Selection = Automatic
Radio Information
Radio power mode = ON
Current Band = WCDMA 2100, Channel Number = 10588
Current RSSI = -93 dBm
Band Selected = Auto
Number of nearby cells = 1
Cell 1
Primary Scrambling Code = 0x81
RSCP = -98 dBm, ECIO = -6 dBm
Modem Security Information
GPS Information
GPS Info
GPS State: GPS disabled
SMS Information
SMS Service is not available
Number of outgoing SMS pending = 0
Any ideas how to get it to work?
12 Replies 12
michael o'nan
Level 4
Level 4
Under the show cellular 0/0/0 all command
Integrated Circuit Card ID (ICCID) = ***SIM card number should be here if it was working.
Michael,
do you mean that either SIM-card or EHWIC is faulty ?
Yes. Possibly the SIM card reader on the card or the SIM card itself? Or it could be as simple as the SIM card is not pushed all the way back. Carefully insert the card and then use something like a flat head screwdriver to ensure the card is pushed all the way back. I've had many times where I put the card in and it comes back out a little bit causing issues.
Hmm, if i'd inserted SIM not properly, i would have had difficulties to lock the slot. But everything seemed good: i inserted the card, pressed it (feeling light back pressure from the contacts), then locked and mounted a screw to fix it.
Some photos are attached. Check it out please.
I'm convinced that the card is inserted right. I repeated 3 times with different working SIMs of different operators.
Could there be another reason of this problem?
Sorry I was referring to the 4G cards as the SIM slot is different...I would say something is wrong with the SIM reader on the card. If you aren't seeing the SIM number in any of the show commands then that seems like a  good indicator.
Michael,
BTW, what do you mean when saying "SIM number"? It seems that we can't see the hardprinted number in any of "show *" commands.
Could you suggest some other "show" commands which could help to localize the issue? Thanks.
The ICCID number that should be printed on the SIM card. When you ran this command:
****THERE IS NOTHING HERE***
Meaning the SIM card is not being read properly by the 3G card and not able to show you the SIM card number. There are no other show commands I would recommend at this time as it seems you have other issues. You may try to power cycle the modem and see if that changes anything.
Router(config)#service internal
Router(config)#exit
Router#test cellular 0 modem-power-cycle
Ok, I think I'll try to reload the module according to commands provided.
But could you explain if there is any difference between cellular 0/0/0 and cellular 0/0/1 ? If yes, what is the purpose of it?
Actually I have only one EHWIC installed in slot 0.
SOLVED!
The problem was in a faulty EHWIC and after some basic steps (e.g. upgrading firmware, rebooting modem and so on) TAC engineer initiated an RMA.
The new module works fine. It recognized the SIM at once and I've already confirured it.
mikik
Hi:
Can some one please send me link to PDF or other document on how to configure a ehwic 3g-hspa+7 ? I need it on a 1921 and am not sure what he different interfaces are used for. Why does one ehwic show me two interfaces?
Mickey
Hi Mickey,
Here is the source: http://www.cisco.com/c/en/us/td/docs/routers/access/1800/1861/software/feature/guide/mrwls_hspa.html#wp1543739 (you can download a .pdf on the same page)
Difference between the two cellular interfaces on EHWIC are also interesting for me, because the configuration done on any will make the EHWIC work. Maybe somebody else could explain.
Hi,is there a future plan that Cisco routers might support voip calls to gsm calls since they have 3G cellular interface
