[SOLVED] Routing Failover on 2911 ISR
chrismerck
Hello All,
I have two 2911 ISRs with the UniversalK9 image:
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.1(3)T3, RELEASE SOFTWARE (fc1)
I want to setup routing failover by using IP SLA and object tracking. I'm following these guides:
1) https://supportforums.cisco.com/docs/DOC-8313
2) http://www.cisco.com/c/en/us/td/docs/ios/dial/configuration/guide/12_2sr/dia_12_2sr_book/dia_rel_stc_rtg_bckup.html#wp1064193
I can setup an IP SLA using ICMP ECHO. This works.
However, next I need to do "track 10 rtr ..." but the "rtr" part is not supported:
TestSub#config t
Enter configuration commands, one per line.  End with CNTL/Z.
TestSub(config)#track 10 ?
  application  Application
  interface    Select an interface to track
  ip           IP protocol
  list         Group objects in a list
  stub-object  Stub tracking object
What should I do? Some people told me I need Advanced IP Services lisence, but I already have it (I think):
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      securityk9    Permanent      securityk9
uc            None          None           None
data          datak9        Permanent      datak9
Chris
cadet alain
Try this: track 10 ip sla  x  where x is your sla instance.
Alain
cadet alain
Alain
Thanks Alain, you are amazing. Routing failover now working like a charm .
