Some Cisco 857s go into rommom mode after reboot
mwilkinson
We've recently had some 857's go into rommon mode after a reboot.The confreg is set correctly (0x2102). Anyone else come across this before and what we can do to prevent it?
Cheers
Miles
spremkumar
Level 9
Level 9
Can you post the output of show version and also the show run here to check / see if all is well from the config prespective.
regds
Sorry the delay. Here's the she ver from my own router which had this problem late last year.
mx_testuser#sh ver
Cisco IOS Software, C850 Software (C850-ADVSECURITYK9-M), Version 12.4(15)T7, RE
LEASE SOFTWARE (fc3)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Thu 14-Aug-08 07:18 by prod_rel_team
ROM: System Bootstrap, Version 12.3(8r)YI4, RELEASE SOFTWARE
mx_testuser uptime is 27 weeks, 1 day, 4 hours, 28 minutes
System image file is "flash:c850-advsecurityk9-mz.124-15.T7.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 857 (MPC8272) processor (revision 0x400) with 59392K/6144K bytes of memory
Processor board ID FCZ1314117B
MPC8272 CPU Rev: Part Number 0xC, Mask Number 0x10
4 FastEthernet interfaces
1 ATM interface
128K bytes of non-volatile configuration memory.
20480K bytes of processor board System flash (Intel Strataflash)
mx_testuser#
During the bootup to ROMmon, did you have any logs for that?
Sorry, I don't have any logs
