Bookmark
Subscribe
319
some protocols can't apear on Cisco 9901 IOS XR Configuration 7.9.21
i have Cisco 9901 with IOS XR Configuration 7.9.21 some protocols can't appear with me like isis
below issue appear
for example, I need router ISIS configurations but below I can't find isis option
(config)#router ?
  bgp     BGP configuration subcommands
  hsrp    HSRP configuration subcommands
  lisp    LISP configuration subcommands
  rib     RIB configuration subcommands
  rip     RIP configuration subcommands
  rpl     IPv6 Routing Protocol for Low-Power and Lossy Networks (RPL)
  static  Static route configuration subcommands
  vrrp    VRRP configuration subcommands
also her I need to enable MPLS LSP
#mpls ?
entropy-label Enable MPLS entropy label
ip-ttl-propagate Propagate IP TTL into the label stack
ipv4 Configure IPv4 parameters
ipv6 Configure IPv6 parameters
label Label properties
lsd MPLS LSD process command
static MPLS Static label and LSP configuration commands
it an IOS issue or a license issue or what ? I don't have much experience with IOS XR
as per below, i think I need to install the package
#show install inactive
Thu Sep 19 15:58:25.193 GMT+3
12 inactive package(s) found:
asr9k-mgbl-x64-1.0.0.0-r7921
asr9k-mcast-x64-1.0.0.0-r7921
asr9k-isis-x64-1.0.0.0-r7921
asr9k-eigrp-x64-1.0.0.0-r7921
asr9k-mpls-x64-1.0.0.0-r7921
asr9k-li-x64-1.0.0.0-r7921
asr9k-mpls-te-rsvp-x64-1.0.0.0-r7921
asr9k-m2m-x64-1.0.0.0-r7921
asr9k-bng-x64-1.0.0.0-r7921
asr9k-ospf-x64-1.0.0.0-r7921
asr9k-optic-x64-1.0.0.0-r7921
asr9k-9000v-nV-x64-1.0.0.0-r7921
but it tried to install it using the below commands but the package was not installed
install add source harddisk:/asr9k-isis-x64-1.1.0.0-r7921.x86_64.rpm
install activate
reload
