some static NAT 's works others do not.
jerry.mcrae
i have a router with some static nat statements that point to our web sites. however some websites work perfectly and some do not. they a natted the same and have worked before. one of our server admins updated the nic driver and after reboot the server isnt reachable from the web - he rolled back the change.
i can see the traffic hitting the acl and i can see it getting natted.
this one works - ip nat inside source static tcp 10.10.11.21 80 65.x.x.21 80 extendable
this one doesnt work - ip nat inside source static tcp 10.10.11.13 80 65.x.x.227 80 extendable
output from sh acl - permit tcp any host 65.x.x.x eq www (48 matches)
any ideas - im stumped?
6 Replies 6
Jon Marshall
Hi Jerry
Without wishing to state the obvious can you ping the servers 10.x.x.x address from the router.
You could try clearing the arp cache and the nat translation for that server but if it all wokrd before the update i would be going back to the server guys.
Jon
yea i can ping the 10.10.11.13.
output from sh ip nat trans - (Pro Inside global)tcp 65.x.x.227:80 (inside local) 10.10.11.13:80 (Outside local)65.x.129.214:1326 (Outside global)65.x.129.214:1326
if i try to telnet from command prompt 65.x.x.227 80 i can see the acl hits and nat trans but i cant connect.
we added a totally new server and natted that box and it doesnt work either - however one web server behind the same ethernet interface works fine.
ill attach the running config.
version 12.2
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps log datetime localtime show-timezone
service password-encryption
hostname NOC-NAT-3600
boot system flash c3620-io3-mz.122-31.bin
logging buffered 5000 debugging
logging monitor alerts
username privilege 15 password xxx
username k privilege 15 password xxx
ip subnet-zero
no ip domain-lookup
ip audit notify log
ip audit po max-events 100
interface Ethernet0/0
description connected to Internet
ip address 65.x.x.2 255.255.255.0
ip access-group VailNet in
ip nat outside
full-duplex
interface Ethernet0/1
description connected to Private
ip address 10.10.11.2 255.255.255.0
ip nat inside
full-duplex
router eigrp 100
network 10.10.11.0 0.0.0.255
auto-summary
no eigrp log-neighbor-changes
ip nat inside source list 1 interface Ethernet0/0 overload
ip nat inside source static tcp 10.10.11.13 80 65.x.x.145 80 extendable
ip nat inside source static tcp 10.10.11.13 80 65.x.x.153 80 extendable
ip nat inside source static tcp 10.10.11.13 80 65.x.x.231 80 extendable
ip nat inside source static tcp 10.10.11.21 80 65.x.x.21 80 extendable -works
ip nat inside source static tcp 10.10.11.21 21 65.x.x.21 21 extendable -works
ip nat inside source static tcp 10.10.11.21 20 65.x.x.21 20 extendable -works
ip nat inside source static tcp 10.10.11.33 8080 65.x.x.241 8080 extendable
ip classless
ip route 0.0.0.0 0.0.0.0 Ethernet0/0
ip route 192.168.10.0 255.255.255.0 172.16.1.5
ip route 192.168.11.0 255.255.255.0 172.16.1.5
ip route 192.168.12.0 255.255.255.0 172.16.1.5
ip route 192.168.13.0 255.255.255.0 172.16.1.5
ip route 192.168.14.0 255.255.255.0 172.16.1.5
ip route 192.168.15.0 255.255.255.0 172.16.1.5
ip route 192.168.16.0 255.255.255.0 172.16.1.5
no ip http server
ip access-list standard TELNET
remark ACL for TELNET
permit 172.16.0.0 0.0.255.255 log
permit 172.17.0.0 0.0.255.255
permit 172.19.0.0 0.0.255.255
permit 172.21.0.0 0.0.255.255
permit 10.10.0.0 0.0.255.255
deny any
ip access-list extended VailNet
remark Traffic From Vailnet
permit tcp any host 65.xx.21 eq www
permit tcp any host 65.xx.21 eq ftp-data
permit tcp any host 65.xx.241 eq 8080
permit tcp any host 65.xx.227 eq www
permit tcp any host 65.xx.227 eq telnet
permit tcp any host 65.xx.153 eq www
permit tcp any host 65.xx.241 eq www
permit tcp any host 65.xx.231 eq www
logging 172.16.1.31
access-list 1 permit 192.168.0.0 0.0.255.255
access-list 1 permit 10.10.0.0 0.0.255.255
access-list 1 permit 172.16.0.0 0.0.255.255
access-list 1 permit 172.17.0.0 0.0.255.255
access-list 1 permit 172.18.0.0 0.0.255.255
access-list 1 permit 172.19.0.0 0.0.255.255
access-list 1 permit 172.20.0.0 0.0.255.255
access-list 1 permit 172.21.0.0 0.0.255.255
access-list 1 permit 172.24.0.0 0.0.255.255
access-list 1 permit 172.26.0.0 0.0.255.255
snmp-server x
snmp-server x
snmp-server host 172.16.1.15 x
banner motd ^C Web Farm NAT Router ^C
line con 0
exec-timeout 60 0
login local
line aux 0
line vty 0 4
access-class TELNET in
exec-timeout 60 0
login local
end
there was nothing wrong with the router or the nat - the default gateway was pointed to the wrong router - not the nat router.
deveshkumar
Clear the mac/ Arp in router as well as switch it is connected to ...
if switch is not managebal reboot it..
This will get the things working..i hope..
Hi Devesh,
I see that you are a new member to this forum and I welcome you here.
At the same time I suggest that you use the most care in reading the full thread before answering, as in this case the issue had been solved already as the original poster indicated.
This to maintain the highest possible level in the NetProf forums. Thanks again!
