NAT
mahesh_kv3
We are having a private lan network ,and we are using the range of 172.30.7.0/24 IP are using and we are also havin g an NAT router .can we able t0 use any other prescribed range of IP in our LAN (ie 5.5.5.0/24)with a NAT router.cud u please clear me the basic doubt?
spremkumar
Level 9
Level 9
hi
are you planning to extend external access to the new ip range ?
regds
Pavel Bykov
Level 5
Level 5
If you are talking about prescribing some hosts outside IP address, and the rest to NAT dynamically (i.e. Using static and dynamic NAT simultaneously) please refer to this document:
http://www.cisco.com/en/US/customer/tech/tk648/tk361/technologies_tech_note09186a0080093f31.shtml
Route_reflector
As I understand ur problem, u want to use some private ips as well as some public IPs within the LAN. AM i Right?
Whats ur NAT router? If its Cisco, and if you have correctly defined ur private pool (only with 172.30.7.0/24) it will not affect ur 5.5.5.0 range and you can directly go out with the source ip range of 5.5.5.0/24 . Belive I answered ur question....
Rate if this helps u...
Rgds..
