Source IP
sergo777
Hi Everybody,
sorry maybe stupid question. I need to reach another server via VPN (in this case FTP server, i need to download a new IOS) from router with some interfaces. I can ping and reach this server when i use source from specific interface (loopback), like
ping 10.10.20.5 source 192.168.5.5
but just "ping" and of cause "copy" doesnt work...
how to put something like "default" source interface? or i have to check availability for all interfaces?
thanks
Harold Ritter
Hi @sergo777 ,
For this specific FTP case, you can use the following command.
ip ftp source-interface <source interface>
this is normal,
Router have two behave
traffic pass through
traffic origin from Router
the issue with ping and VPN is that the router origin of traffic and hence the router have des. and need Src.,
Src. is issue here
if you not write the Src. the router will select nearest IP to des. BUT this sometimes is not reachable from other Peer and hence the ping is failed.
so it better to use ping with source in case of test VPN and BGP.
Thanks!
but my goal is not a ping, i need to use FTP for download and upload....  i think, i have to check all interfaces, all of them should reach dest.
Harold Ritter
Hi @sergo777 ,
sergo777
Thanks Harold! it works!
