SPAN on 3945
Hi, I am having trouble configuring SPAN on a 3945 with 15.0(1r)M13. gi0/0/0 is a HWIC I added because I was seeing the same behavior on the onboard ports. Is there a specific issue with this or am I mussing something?
rt(config)#monitor session 1 source interface gi0/0/0
% Incomplete command.
rt#sh int desc
Interface                      Status         Protocol Description
Em0/0                          admin down     down
Gi0/0                          down           down
Gi0/1                          up             up
Gi0/2                          down           down
Gi0/2.472                      down           down
Gi0/0/0                        up             up
Gi0/0/0.10                     up             up
Jacques
Mark Malone
Hey
wont work on on-board ports span sessions not supported on routers , should work though on a EHWIC as per doc not sure on standard HWIC for 39 but HWICs are supported on 29 routers
What options does it give after the g0/0/0 ?
http://www.cisco.com/c/en/us/td/docs/routers/access/interfaces/software/feature/guide/geshwic_cfg.html
Mark Malone
Hey
Sorry, MS Edge problems. Thanks, came right with embedded capture though. Only problem is DSCP marking is done after the capture is done, so not going to help carriers. But intermediary switch is the answer through. Pain the ass! No EHWICs.
Jacques
