spanning layer 2 over mpls - xconnect or vfi ?
dinesh2001
Hello people,
I am trying to span layer 2 using mpls, on Cisco ASR920. I have a vlan (vlan 400) coming in on an interface (g0/22) on a Cisco ASR920, and i want to span it over to another ASR920 as layer 2. But............ there are 2 ways i can do this...  Please could someone suggest what the difference in the ASR920 config below is? I don't have a lab and don't want it to fail when trying to put it into production...
CE1 ----------- PE1 (ASR920)-----------MPLS ----------- PE2 (ASR920) ----------- CE2
                      int g0/22
Option 1:
interface pseudowire10
encapsulation mpls
neighbor 2.2.2.2 10
l2vpn xconnect context 10
member pseudowire10
interface GigabitEthernet1/0/22
service instance 400 ethernet
encapsulation dot1q 400
rewrite ingress tag pop 1 symmetric
xconnect 10.4.6.6 400 encapsulation mpls
Option 2:
l2 vfi 400 manual
vpn id 400
neighbor 2.2.2.2 pw-class vpls400
interface vlan400
no ip address
xconnect vfi 400
bridge-domain 400
interface GigabitEthernet0/22
bridge-domain 400
Giuseppe Larosa
Hello @dinesh2001 ,
option 1 is a point to point L2 service EoMPLS psuedowire
option 2 using VPLS is a point to multipoint service and would allow to add a third site later
So what to use really depends on what can be useful on the future.
I
Hope to help
Giuseppe
thank you, I dont plan to use a third site.so i could use either. I guess the simplest config would be the best.... any suggestions on which is the simplest and most reliable.. ie not likely to be affected by bugs?
