Spanning tree issue on C1111 router
WilsonCheng
Spanning tree was configured and enabled on C1111 router, but show spanning tree shows no spanning tree information as below. Does anyone know what the issue is and how to fix it? Thank you.
router#sh run | s spanning
spanning-tree vlan 1,599,990 priority 61440
router#sh ip int brief
Interface              IP-Address      OK? Method Status                Protocol
GigabitEthernet0/0/0   #####    YES NVRAM  up                    up
GigabitEthernet0/0/1   unassigned      YES NVRAM  administratively down down
GigabitEthernet0/1/0   unassigned      YES unset  up                    up
GigabitEthernet0/1/1   unassigned      YES unset  administratively down down
GigabitEthernet0/1/2   unassigned      YES unset  administratively down down
GigabitEthernet0/1/3   unassigned      YES unset  up                    up
Vlan1                  unassigned      YES unset  administratively down down
Vlan599                10.250.182.226  YES NVRAM  up                    up
Vlan990                10.41.98.2      YES NVRAM  up                    up
router#sh spanning-tree
No spanning tree instance exists.
router#sh spanning-tree sum
Switch is in rapid-pvst mode
Root bridge for: none
EtherChannel misconfig guard            is enabled
Extended system ID                      is enabled
Portfast Default                        is disabled
PortFast BPDU Guard Default            is disabled
Portfast BPDU Filter Default           is disabled
Loopguard Default                      is disabled
UplinkFast                              is disabled
BackboneFast                            is disabled
Configured Pathcost method used is short
Name                   Blocking Listening Learning Forwarding STP Active
Total                        0         0        0          0          0
25 Replies 25
balaji.bandi
This is an Router, until you have a switch module in it, it can not act as a switch, so that is normal
BB
The router has a switched module and the trunk port allows the vlans. All
C1111 routers in our network also have the same issue. I wonder if it is a
bug.
router#sh run | s vlan
vlan internal allocation policy ascending
vlan 599
name UNTRUSTED_DEVICES
vlan 990
name DEVICE_MANAGEMENT
router#sh int trunk
Port Mode Encapsulation Status Native vlan
Gi0/1/0 on 802.1q trunking 990
Port Vlans allowed on trunk
Gi0/1/0 1-4094
Port Vlans allowed and active in management domain
Gi0/1/0 1,599,990
Port Vlans in spanning tree forwarding state and not pruned
Gi0/1/0 1,599,990
ok as per the output the spanning-tree running :
try below :
show spanning-tree vlan 599
show spanning-tree vlan 900
https://www.cisco.com/c/en/us/td/docs/routers/access/interfaces/NIM/software/configuration/guide/4_8PortGENIM.html#pgfId-1079138
BB
router#sh spanning-tree vlan 599
Spanning tree instance(s) for vlan 599 does not exist.
router#sh spanning-tree vlan 990
Spanning tree instance(s) for vlan 990 does not exist
Hello
do you have any ports assigned to those vlans that are active or even an active trunk?
Also have you created the vlans?
vlan 599,990
exit
Kind Regards
Paul
The vlans were created and the trunk port allowed the vlans. All C1111
routers in
our network also have the same issue. I wonder if it is a bug.
vlan 599
vlan 990
router#sh int trunk
Gi0/1/0 1-4094
Gi0/1/0 1,599,990
Gi0/1/0 1,599,990
Hello
Gi0/1/0 1-4094
Gi0/1/0 1,599,990
Gi0/1/0 1,599,990
Looks like you do have stp running
show spanning-tree interface gig0/1/0
Kind Regards
Paul
I am not sure if the spanning tree is running or not.
Show spanning tree is no spanning information.
Router#show spanning-tree interface gig0/1/0
no spanning tree info available for GigabitEthernet0/1/0
Hello
can you post the output of the following into a file and attach to this post.:
sh ip int brief
sh vlan brief
sh cdp neighbour
sh in trunk
sh spanning-tree detail
sh run
ah version
Kind Regards
Paul
GigabitEthernet0/0/0 xxxxxxxxxxxx YES NVRAM up up
router#
router#sh vlan brief
VLAN Name Status Ports
1 default active Gi0/1/1, Gi0/1/2
599 UNTRUSTED_DEVICES active
990 DEVICE_MANAGEMENT active
1002 fddi-default act/unsup
1003 token-ring-default act/unsup
1004 fddinet-default act/unsup
1005 trnet-default act/unsup
router#sh spanning-tree detail
router#sh cdp nei
router#sh cdp neighbors
% CDP is not enabled
router#sh int trun
Gi0/1/0 1-4094
Gi0/1/0 1,599,990
Gi0/1/0 1,599,990
router#sh ver
Cisco IOS XE Software, Version 16.09.07
Cisco IOS Software [Fuji], ISR Software (ARMV8EB_LINUX_IOSD-UNIVERSALK9_IAS-M), Version 16.9.7, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2021 by Cisco Systems, Inc.
Compiled Wed 10-Feb-21 08:19 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2021 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
router uptime is 10 weeks, 5 days, 13 hours, 30 minutes
Uptime for this control processor is 10 weeks, 5 days, 13 hours, 32 minutes
System returned to ROM by PowerOn
System restarted at 12:31:11 GMT Thu Sep 9 2021
System image file is "bootflash:c1100-universalk9_ias.16.09.07.SPA.bin"
Last reload reason: PowerOn
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Suite License Information for Module:'esg'
Suite Suite Current Type Suite Next reboot
FoundationSuiteK9 None None None
securityk9
appxk9
Technology Package License Information:
Technology Technology-package Technology-package
Current Type Next reboot
appxk9 appxk9 Permanent appxk9
securityk9 securityk9 Permanent securityk9
ipbase ipbasek9 None ipbasek9
The current throughput level is unthrottled
Smart Licensing Status: Smart Licensing is DISABLED
cisco C1111-4P (1RU) processor with 1452657K/6147K bytes of memory.
Processor board ID FGL2528L5VT
3 Virtual Ethernet interfaces
6 Gigabit Ethernet interfaces
4294966432 terminal lines
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
2945023K bytes of flash memory at bootflash:.
0K bytes of WebUI ODM Files at webui:.
I haven't followed the entire discussion, but by default, spanning tree is disabled for all Vlans on the C1111.
You need to manually enable it:
C1111(config)# spanning-tree vlan 599
The spanning-tree vlan x command was already configured before and accepted
with no error but it doesn't show up in running configuration.
Hello
it does seem unusual that the rtr is stating the vlan are in a stp forwarding state but stp is not running
I-believe what @Georg Pauwen is stating is to re apply stp again without any priority
Kind Regards
Paul
Hello Paul,
I have done the spanning-tree vlan x without priority with no error
prompt but I checked with the running configuration, it is not there. show
spanning tree still showed no spanning tree information. It is very
strange. I wonder if it is a bug or not.
